Fitting 20" AM wheels from the 2018+ Vantage on a DB9
Old Sep 12, 2023 | 04:00 PM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
Has anybody fit 20" wheels from the 2018+ new vantage on a DB9? I think the bolt pattern is different so it would prob need an adapter but I'm not sure which one?
I understand from other posts that the factory 19" wheels on a DB9 are:
DB9-- 19 x 8.5 et +50.3; 19 x 9.5 et +62.5; Tire size is 235.40.19 front; 275.35.19 rear
Whereas, the 20" wheels on the new Vantages are: 20 x 9 et +48, 20 x 11 et +55; Tire size is 255.40.20 front; 295.30.20 rear
Thanks!
Old Sep 13, 2023 | 08:02 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
You might be better off going to a company like Forza (link) and asking if they can make forged reproduction wheels with the correct offset and bolt pattern to fit your DB9. Page 2 on that link has new Vantage wheels in the range of $1800 per set. Seems reasonable.
Disclaimer: I don't know much about that company, it came up when I did a search for OEM reproduction Aston wheels. I'm sure they're not the only ones out there.
Old Sep 15, 2023 | 06:09 AM
Phil57DBS's Avatar
5 Year Member
Phil57DBS is infamous around these parts
this is not mountable!
the DB9 fixing centers are 114 diameter.
the Vantage 2018+ and DB11 fixing centers are 128 diameter!
Old Sep 15, 2023 | 02:19 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
the Vantage 2018+ and DB11 fixing centers are 120 diameter!
The DB11 and pretty sure the 2018+ Vantage as well, have wheel bolt patterns of 128 mm
Old Sep 16, 2023 | 08:36 AM
J doubleU's Avatar
Correct on the 128mm which started with Rapide 2010 Vanquish 2014 DB11 and current Vantage all are of the same wheel bolt diameter. Stay away from lug adapter mods that modify bolt patterns, creates more issues.
Old Sep 18, 2023 | 01:48 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Can DB11 Wheels fit on a Rapide and vice versa?
Old Sep 18, 2023 | 08:46 PM
J doubleU's Avatar
Most likely due to the bolt and hub pattern, I would recommend a trial fitment before buying. Vanquish wheels would look look nice on a Rapide.....
brightoncorgi
Apr 9, 2023 01:40 PM
SheriffDep
Mar 24, 2023 08:53 AM
Pigdog
Feb 17, 2017 11:49 PM
corveight
Jan 4, 2016 09:14 PM
klvnwee
Jan 16, 2011 02:42 PM
