DB11 wheels on Rapide?
Old Nov 16, 2023 | 08:07 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Good morning, I am looking at getting new wheels for my 2010 Rapide, and I have set my eyes on a set of 20" wheels out of a DB11.
They're 20x9 ET48 for the front, 20x11 ET55 for the rear.
However, I can't make sure 100% that there will be enough clearance under the arches.
Has a fellow Rapide owner ever installed this kind of setup on his Rapide? Did that fit properly?
Thanks in advance for the help!
Old Nov 16, 2023 | 09:22 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I thought the Rapide had a unique wheel setup that wasn't shared with other models?
Old Nov 16, 2023 | 09:40 AM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Lug spacing may not be the same.
Old Nov 16, 2023 | 10:06 AM
EJ_Rapide's Avatar
From what I understood, the bolt pattern is the same with the Vanquish (seems to be a straight installation) and the DB11 (I'd like to make sure of that prior to purchasing the wheels).
Or maybe the seller might be confused?
Old Nov 16, 2023 | 10:30 AM
EJ_Rapide's Avatar
Originally Posted by LuvBurninFuel
Might start here.
https://bolt-pattern.com/
Thanks for the link!
DB11 wheels are out
Old Nov 16, 2023 | 11:00 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
DB11 wheels are out
The information above (post 5) regarding the DB11 wheel bolt pattern diameter is incorrect. The DB11 uses a 5x128 pattern and a 75mm center bore. This I've verified. I own a DB11 and was looking at wheel spacers. I used info from this site to start, then verified with my actual wheel.
I am only commenting about the wheel bolt pattern dia, and not the offsets.
I do not know if the bolt pattern changes when the V8 is used, but highly doubt that.
Old Nov 16, 2023 | 11:05 AM
EJ_Rapide's Avatar
Which website is that?
If I may ask?
Thank you.
Old Nov 16, 2023 | 11:09 AM
BWings's Avatar
5 Year Member
If I may ask?
Thank you.
https://www.wheel-size.com/size/aston-martin/db11/2016/
I am posting this but might get taken down by admin.
Old Nov 16, 2023 | 11:34 AM
EJ_Rapide's Avatar
Seems pretty close!
Old Nov 16, 2023 | 03:41 PM
J doubleU's Avatar
Don't count out the Vanquish wheels from 2014-18. Mich better looking than the DB11 IMO.
Old Nov 16, 2023 | 05:01 PM
BWings's Avatar
5 Year Member
Seems pretty close!
Very close. The front wheels are a little narrower (8.5" to the 9" used on the DB11). Offsets a little different.
Don't know how it would work out on the Rapide, but on my DB11 I've increased tire sizes from stock
Fronts
Factory 255/40/20 and I went to 275/40/20
Rears
Factory 295/35/20 and I went 315/35/20
Old Nov 17, 2023 | 05:21 AM
corveight's Avatar
corveight is infamous around these parts
when I looked into this I was told the bolt pattern is different. I know the hub and bearing has a different part number from the DB9.
Old Nov 17, 2023 | 05:34 AM
BWings's Avatar
5 Year Member
Hi @corveight
The Rapide and DB9 wheel bolt patterns are not the same. The Rapide has a 5x128mm pattern which is the same as that on a DB11. The DB9 has a different pattern than these models.
Old Dec 9, 2023 | 09:04 PM
EJ_Rapide's Avatar
So, the answer is yes, you can mount DB11 wheels on a Rapide.
I installed my new (to me) rims today, everything went well, no need for spacers or anything.
Pretty happy with the results!
Old Dec 10, 2023 | 06:22 AM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
Looking good!
