Power Windows Switch
Old Nov 30, 2023 | 09:26 AM
mbrandt1402's Avatar
mbrandt1402 is infamous around these partsmbrandt1402 is infamous around these parts
I miss having "one touch" power windows for both sides and in both directions. There are aftermarket electronic modules available, and I suspect it might also be possible to reverse the wiring to the motors so that the switch works logically (i.e. up is up, down is down).
Has there ever been a version of the driver's side window switch that did not contain the one-touch feature? I'm not sure how the one-touch OEM feature would affect an aftermarket module. Using a switch w/o that feature (which I have done in a previous car) would eliminate any question of compatibility.
Old Dec 4, 2023 | 12:05 AM
PhuketPaul's Avatar
PhuketPaul is infamous around these partsPhuketPaul is infamous around these parts
If you are going to reverse the direction of the switches, I would change the wiring at the switch rather than the motor, The automatic drop and raise when you are opening/closing the door wouldn't work very well with the wiring reversed at the motor!
Old Dec 4, 2023 | 06:34 AM
embdenb's Avatar
Changing the wiring on these window switches has been on my “to do” list for quite some time
Old Dec 4, 2023 | 02:26 PM
Yup, reversing the wires at the motor would screw-up the automatic window dip and seal when the doors are opened/closed, so that was never under consideration. PhuketPaul, I'm glad you posted that, just in case someone was inspired to do this but forgot about that feature.
Aualex2
Sep 4, 2023 02:47 AM
pleasereset
Dec 18, 2017 09:18 PM
timwhayden
Oct 15, 2013 07:44 PM
911t-gts
May 27, 2012 04:38 PM
Car-Narcissist
Nov 20, 2011 04:21 PM
