My12 Rapide Cheap Coil Question
Old Dec 23, 2024 | 06:13 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Make sure you get the right coil if ordering DM Coil. They sent me the wrong coil's and I end up buying OEM instead.
Old Dec 24, 2024 | 07:36 AM
viglaman's Avatar
viglaman is infamous around these parts
DMCoil's reply regarding the red coil packs.
"The output voltage and ignition energy are both greater than 10% higher than standard coils."
I got the black ones and to be honest they are fine.
Old Dec 24, 2024 | 12:08 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I suspect it was a question of the # of pins in the connector. The older wiring harnesses carried three wires to the coil, the newer ones are just 2 pin connectors.
Old Dec 24, 2024 | 12:40 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Isn't it the other way around? 2005 and some 2006 were two pin, then they switched to three?
Old Dec 24, 2024 | 01:44 PM
viglaman's Avatar
DMCoil's both coil packs are 3-pin. I think they do not offer 2-pin ones.
Old Dec 25, 2024 | 05:03 AM
Geflackt's Avatar
Geflackt is infamous around these parts
If someone still needs coils for a Rapide, I still have this MSD coil set available that may match a Rapide:
https://www.6speedonline.com/forums/...ks-v-12-a.html
I originally thought they would match my Vanquish but the coil body is different.
Here's the Rapide article where they were used:
https://www.6speedonline.com/forums/...xperience.html
Old Dec 27, 2024 | 06:59 PM
J doubleU's Avatar
I have just replaced coils and plugs on 2011 DBS. I sourced very inexpensive eBay coils as an experiment and used OEM updated spark plugs. Car has 20k mi. So I'll check it regularly to see how they hold up.
Less than $100 for 12 coils, running like a proper V12 after repairs.
ID:	545243   Click image for larger version
ID:	545244   Click image for larger version
Old Dec 30, 2024 | 03:20 AM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Correct; the earlier cars have 2 pin with the later models (05/06 onwards) fitted with the 3-pin version
Old Apr 18, 2025 | 11:47 AM
huesey1974's Avatar
huesey1974 is infamous around these parts
Hi,
How are the DMCOIL's holding out? Seem to get good reviews on a few sites for other manufacturers.
Old Apr 21, 2025 | 01:18 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I'm also interested to know how the red DMCoils are holding up. My Vanquish is approaching 38k miles and a DBS owner recently recommended I change them soon.
Just looked them up on Amazon, and $419 is a damn good price for 12 coils.
Old Apr 21, 2025 | 01:21 PM
5 Year Member
I am happy with my DMCoils.
Old Apr 29, 2025 | 11:56 AM
Kalepsis's Avatar
5 Year Member
What spark plugs would you recommend pairing with them?
Old Apr 29, 2025 | 01:02 PM
5 Year Member
I went with the OEM NJK's.
Old Apr 29, 2025 | 04:06 PM
Kalepsis's Avatar
5 Year Member
Oh, wow, I just searched for the CD33-12405-AA-PK and... yeah... a set of twelve spark plugs costs more than the set of DMCoils! What?!
I found a set on Ebay for 260, shipping within the US (so no tariffs, thankfully). Jumped on them. I hope it's not a scam.
Old Apr 30, 2025 | 06:53 AM
5 Year Member
I think I bought mine from Aston Martin Bit or Scuderia. I am sure if you went by just the part number they could be found less expensive, but you wouldn't the nice white box for each plug.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
