newbie
Old Jan 27, 2024 | 09:31 AM
AbacoBoy's Avatar
AbacoBoy is infamous around these parts
newbie
Hey Guys,
I have a 2007 Aston Martin DB9 that I bought in Canada. It was originally imported to the US, and was converted to metric when it was in Canada. I need to change the odometer back to US (miles). What is involved? Thanks for any guidance.
Bruce
Old Jan 27, 2024 | 09:57 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Are you sure the odometer is in km and not just the speedometer? I had a 2006 DB9 imported from the US to Canada and the odo was always in miles.
Press the Read button (next to the T1 / T2 button) and the button on the end of the left stalk together, and hold for 3 seconds to switch the speedo between miles & km.
Only other change for Canada is daytime running lights. I think the dealer has to do that.
Old Jan 27, 2024 | 10:28 AM
AbacoBoy's Avatar
The odometer is definitely in kilometers. The speedo is showing miles per hour.
Old Jan 27, 2024 | 04:59 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
My 08 was imported from the USA to Canada…reads kms..
Old Jan 29, 2024 | 08:04 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
I just had a 2014 V8V Canadian car brought in and converted to US. Gauge cluster had to be changed. Stalk + read button action will change all the info over to US except the readout of the center console radio/temperature screen, which required an AMDS tool to convert.
Old Jan 30, 2024 | 04:21 AM
handyman2009's Avatar
Veteran: Canadian Forces
AbacoBoy, can you show us your gauges? That would help us point you in the right direction
Old Jan 30, 2024 | 09:07 PM
GWP's Avatar
GWP
5 Year Member
Are you asking for a picture of the gauge cluster?
Old Jan 31, 2024 | 04:11 AM
Yes as I wanted to see which numbers were bigger Miles or Kms as you know the little digital display can be changed to show either
Old Jan 31, 2024 | 12:45 PM
GWP's Avatar
GWP
5 Year Member
The change of the speedomoter face is the only thing different between the US and Metric gauge clusters. Whichever one you choose has the predominant numbers larger and on the outer side of the gauge face. Attached is a picture of the US gauge face. Hope that is what you were wanting to see.
Old Apr 22, 2025 | 07:54 AM
Flachbau930's Avatar
Flachbau930
GWP, did you ever get this issue with the odometer resolved? I'm in the same boat.....V8 Vantage sold in U.S. and then relocated to Canada. Now, odometer reads kilometers and headlights always on.
Old Apr 22, 2025 | 08:07 AM
To pass safety check in Canada and be registered you need Daytime Running Lights and the Vantage didn't come equip with some so the dealership using the AMDS change the lights to be always on as soon as the car is started. That could be reverted by someone with AMDS as it is only software controlled
Old Apr 22, 2025 | 08:19 AM
Flachbau930
handyman2009, thanks for your reply.
Have you heard anything about the odometer getting the odometer to read out miles instead of kilometers? I heard some horror story that the display unit has to be replaced or reprogrammed by the factory......
Old Apr 22, 2025 | 10:26 AM
you can change the digital display to be in Miles or Kilometers but if you want the dials and odometer to be in miles you will have to replace the full instrument cluster and get it reprogramed with someone who has a AMDS (usually dealership).
Old Apr 22, 2025 | 08:14 PM
GWP's Avatar
GWP
5 Year Member
Yes, changed out the instrument cluster so mph info was prominent then got into the owners manual for the info to convert the digital readout. Fairly simple procedure.
Old Apr 23, 2025 | 11:02 AM
Flachbau930
Thanks for your reply. It appears that when the Vantage owner moved back Canada, he had to get it 'federalized' to Canadian vehicle standards. As far I as know, this required the ECU be reprogrammed to have the headlights on at all times and the odometer read distance in kilometers.
Thanks to feedback from of Aston Martin enthusiasts, a AMDS diagnostic tool is required to convert it back to U.S. standards. I spoke to the Chicago area Aston Martin service manager about the conversion process and he knew nothing about it, but will investigate.
ianabbott
May 29, 2017 10:57 AM
Tuskir
Jul 18, 2013 10:43 PM
///M_Chap
Jun 6, 2008 03:23 PM
Neil@Orton
Oct 28, 2006 08:35 PM
