Rapide Switched Fuses
Old Feb 26, 2024 | 09:23 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Good evening,
I apologize in advance for the basic question, but which of these fuses would be "switched" fuses in the cabin fuse box?
I installed a backup camera and a Naviks unit a couple weeks ago, and my battery has since drained (I was able to recharge it, thankfully), so I suspect I used fuses that were "hot" all the time.
Which 2 fuses would be the best choices then?
Thanks in advance for the help!
Old Feb 27, 2024 | 07:20 PM
MikeD's Avatar
MikeD is infamous around these parts
Sorry if this sounds curt. Your camera will draw insignificant current. Just tap into any fuse that's hot only when the ignition is on. Get a meter, pull the fuse and check the hot side for power, ignition on and ignition off.
Old Feb 27, 2024 | 07:59 PM
EJ_Rapide's Avatar
Thanks for the answer, I'll try this out.
On another note, if I need, let's say, 5A to feed the camera, can I tap into a 10 or 25A fuse? Or it has to be a 5A fuse?
Old Feb 28, 2024 | 07:21 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Inexpensive Fuse Tap
[QUOTE=On another note, if I need, let's say, 5A to feed the camera, can I tap into a 10 or 25A fuse? Or it has to be a 5A fuse?[/QUOTE]
Buy a fuse tap (of the correct type - ATM or Mini ATM) at your local auto store and then use whatever fuse is necessary to protect your camera circuit.
Old Mar 9, 2024 | 07:34 PM
EJ_Rapide's Avatar
I ended up taping power on F7 and F22. Will monitor potential leak over a couple days before I call it a win.
Thanks for the help!
Old Dec 22, 2024 | 11:00 AM
Hashmanx's Avatar
Hashmanx
Did that work? I’m trying to hardwire a radar detector and can’t figure out which fuse to tap into for power when vehicle is on.
Old Dec 22, 2024 | 12:10 PM
EJ_Rapide's Avatar
It did, yes, No more battery drainage since I tapped into these 2 fuses.
NigelM
Bentley
Aug 29, 2023 11:18 AM
Prajwas2004
Jun 25, 2015 10:40 PM
kansha530
Cayenne 955/957
Jan 14, 2015 06:30 PM
Gusto88
Sep 19, 2014 08:29 PM
thxbuff2001
Feb 20, 2011 07:38 PM
