My "Emergency" key is a joke! Stuck in ignition 2x
Old Mar 3, 2024 | 06:53 PM
MikeD's Avatar
MikeD is infamous around these parts
Originally Posted by yvr
I bought one of those from ambits a few months ago to tidy up my worn valet key. You just swap the internals from your old one to the new one. That includes the little chip that's glued in and has to be cut out, moved, and glued in to the new case. Easy.
If you want to spend more, these guys will do pretty much anything "phoenixbespokekeys . com/product/aston-martin-glass-ecu-key-button-upgrade/"
That company does some cool stuff and although pricey it seems less expensive than buying another key or housing from Aston.
Old Mar 4, 2024 | 05:38 AM
sweet991S's Avatar
5 Year Member
sweet991S
Many Thanks - doesn't look "too" hard.......LoL
Old Apr 1, 2024 | 05:30 AM
sweet991S's Avatar
5 Year Member
sweet991S
I guess I will find out just how this will work....based upon your (collective) recommendations I just ordered a Astonbits replacement key fob and look forward to fiddling with it- removing the guts from my old one into the new one.
NOT
Old Apr 1, 2024 | 09:24 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
I ordered a valet key from them, and it was a perfect replacement.
Old Apr 1, 2024 | 10:59 AM
sweet991S's Avatar
5 Year Member
sweet991S
Great - was it difficult to swap out the innards?
Old Apr 1, 2024 | 04:27 PM
EJ_Rapide's Avatar
The key fob was pretty easy, yes.
I don't know about the chip, since it stayed inside the case and I had the dealer program it.
Old Apr 1, 2024 | 04:35 PM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
If your key still works, it's also possible to buy the 2nd key as a cage / service part (buttons, screws etc) without the inner board that you just need to transfer. It's part # 9G43-19H477-CA for the 315MHz and 9G43-19H477-DA for the 433MHz . You might be able to get it cheaper than a whole replacement key
Old Apr 7, 2024 | 04:40 PM
sweet991S's Avatar
5 Year Member
sweet991S
Many Thanks to you sir....!
Old Apr 7, 2024 | 07:38 PM
ram_g's Avatar
5 Year Member
ram_g
Is this “cage” basically the complete outer case with the only thing missing being the little green circuit board inside? In the picture it appears that the little PATS chip is even included…is that correct?
Thanks!
x X CLoud X x
Nov 26, 2022 02:53 PM
mziegler38
Oct 29, 2013 02:17 PM
Pike1181
Jan 30, 2013 06:43 AM
