Code: Bank 1 # 1 O2 sensor
Old Mar 23, 2024 | 08:20 PM
Stucat's Avatar
5 Year Member
Stucat is infamous around these parts
Question Code: Bank 1 # 1 O2 sensor
Is there a way to test the O2 sensor's to c if they are working correctly? Also are the heated sensor's? on a 2009 DBS with 16,500 miles. I was told they are probably Ford sensor's?
Old Mar 24, 2024 | 05:40 AM
V8Vdrew's Avatar
5 Year Member
V8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the rough
I would hook up a reader and look at the voltage going through the sensors to see if they are operating correctly.
Old Mar 24, 2024 | 09:41 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Yes, as V8VDrew suggests, the voltage pattern for the front sensors which control the fuel trims is an oscillating one traveling in the range of 0.1 to 1.0 volts, with .45v representing stoichiometric fueling (14.7:1).
One of the simplest charts I like to reference is this one. No O2 sensor will look like the suggested perfect pattern, but closest to it is a good sensor. Both engine and sensor must be up to operating temps.
Old Mar 24, 2024 | 11:11 AM
BWings's Avatar
5 Year Member
Here is a real example of the O2 front sensor outputs. This came from a car I was tuning. In this particular live data screen catch, engine was idling. The O2 sensor STFTs outputs are shown in the fourth row as light blue and purple. Here I have the scale set to %s and not actual voltages but the pattern is the same. This is a healthy O2 pattern.
Old Mar 25, 2024 | 08:51 AM
Stucat's Avatar
5 Year Member
Thanks. when I get a chance I will have to drive the car around to get up to temp, then hook up to the meter when at idle and see what it reads. Thanks again
Old Mar 25, 2024 | 03:10 PM
ram_g's Avatar
ram_g
I do not disagree with the previous posts on how to test the sensors. But I have a different take on what I would do in your situation. These are standard Ford / Motorcraft sensors and there is a new universal part that fits them all - both upstream and downstream - DY1401. In order to test the sensors you have to access the connectors which is a bit of a PITA for the upstream ones. If you’re going to do that anyway, I would simply spring for a set of new Motorcraft ones and replace them all. You do not have to buy expensive Aston Martin parts for this.
Edit - yes they are heated sensors.
Old Mar 25, 2024 | 03:14 PM
BWings's Avatar
5 Year Member
This IS a very good idea. I access data via the OBD port, but I'm using hack SW and not everyone can do it that way. Maybe even better just starting out fresh.
Old Mar 25, 2024 | 05:33 PM
Stucat's Avatar
5 Year Member
I was thinking that was a lot of work to access the sensor's and test while running. I also read an article on the Ford O2 sensor's. On replacing the sensor's , would that be all 4 up front? Or are there 4 more near the cats? Thanks
Old Mar 25, 2024 | 06:53 PM
ram_g's Avatar
ram_g
For a DBS the V12 has 8 (gulp!) O2 sensors.
If you haven’t already, go to aston1936.com and look around. He has a 2005 DB9 but the general layout of the engine is the same.
tranceatlantic
Oct 6, 2024 08:18 PM
exilebrit
Jan 24, 2024 07:50 AM
F430Spider
Bentley
Aug 9, 2010 05:19 PM
Harmony Jim
May 17, 2010 05:39 PM
DNugget991GT3
Aug 19, 2008 10:21 AM
