New to me V12 Vantage 6 speed
Old Apr 19, 2024 | 03:34 PM
  #31
J doubleU's Avatar
Fuse is #22 on a 2011 V12 and V8 for the exhaust vacuum pump. People that don't know disconnect the vacuum lines instead of the fuse. Or it could have a failed vacuum pump. I would sort out if the valves are working first, secondary bypass for the $ vs sound and easy installation would be second.
Old Apr 19, 2024 | 08:43 PM
  #32
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
My vacuum pump was buzzing when ignition was on (but not the engine) so I assumed it had failed and ended up pulling fuse 22. And later on, I added a Larini decat system. Love the sound of the V12 now!
And no more buzzing vacuum pump
Old Apr 20, 2024 | 12:23 AM
  #33
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
Most of the decat pipes are same( it's just a straight pipe replacing secondary cats) unless it's x-pipe design, what does your larini decats look/sound like?
Old Apr 20, 2024 | 10:29 PM
  #34
007JB's Avatar
​​​​​​fun to be in driver seat, but no fun doing anything under hood, no room! Let the fun begin. Major service is in the order....
Old Apr 24, 2024 | 10:46 PM
  #35
007JB's Avatar
Had a chance to check exhaust valves today, I have checked fuse & plumbing & vacuum hose/pump & solenoid everything is connected as it should be, but valves are always open, connected my vacuum pump to vacuum source no vacuum to valves when car is cold or warmed up, checked valves with vacuum pump , they open & hold vacuum . Am I missing something? Starting to think, maybe it has a tune to keep valves open all the time?
Old Apr 25, 2024 | 01:18 AM
  #36
matt75321's Avatar
matt75321 is infamous around these parts
what was the major service it needed? Or just catching up on the 5 to 10 year interval stuff?
Was this the car recently for sale in AZ? You beat me to it- seemed like listing was only up for a couple days great find!
Old Apr 25, 2024 | 07:31 AM
  #37
007JB's Avatar
Just doing all the fluids, filters, belt, tensioner, door/hood/trunk struts. want to start with fresh. Next -ordered Velocity AP X-pipe & 11MM H&R spacers. I think that would be it..... And paint correction & ceramic coating.
Yes, I did purchased from AZ.
Old Apr 25, 2024 | 09:55 AM
  #38
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
You sure it's an OEM exhaust?
Old Apr 25, 2024 | 09:58 AM
  #39
007JB's Avatar
Yes, all stock OEM, no mods at all.
Old Apr 25, 2024 | 10:03 AM
  #40
5 Year Member
Are you basing the valves open all the time on just it idling or hear no difference driving? No difference in sound at 2K driving vs. 5K?
Old Apr 25, 2024 | 10:11 AM
  #41
007JB's Avatar
Valves are open all the time at idle, cold or warm start or idling. scanned for codes, none found, so I'm assuming its programmed to stay open all the time..
Old Apr 25, 2024 | 10:18 AM
  #42
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Have you checked the line with the car running to see if it's actually drawing vacuum? Solenoid could have failed, line could have a hole etc.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Apr 25, 2024 | 10:34 AM
  #43
007JB's Avatar
I checked while car running, I get vacuum from the pump and to tank, (not leaking there) but no vacuum to valves on both sides. I was thinking about solenoid, but wouldn't it have created trouble code for that?
I'll check that next, I don't mind valves staying open all the time, but just wanted find out why..
Old Apr 25, 2024 | 10:36 AM
  #44
5 Year Member
They're supposed to be open at idle, no? Driving is when you notice if the valves are working or not.
Old Apr 26, 2024 | 12:22 AM
  #45
007JB's Avatar
Not sure about that, I thought it suppose to be open when engine is cold and close after few minutes when it goes to closed loop at idle.... in my case I had the car running for 10+ min but valves are still open.
007JB
Mar 8, 2024 01:00 AM
Fla993
Jul 1, 2021 08:18 PM
dpath
Jan 10, 2021 02:36 PM
royis
Mar 25, 2013 09:54 AM
scottblack
May 4, 2011 10:42 PM
