Lift pucks
Old Apr 8, 2024 | 12:24 PM
Jorgens's Avatar
Jorgens is infamous around these parts
Lift pucks
Hi all, maybe a daft q, but what kind of "pucks" do you use when lifting your car on a scissor lift? Mine is a 06V8V, and I`m afraid to damage the plastic that wraps around the sills...
Cheers
Jørgen
Old Apr 8, 2024 | 01:25 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
You can special order from https://hsmprecision.us/collections/...rtin-jack-pads. Or do like I did and ordered ones off amazon and cut them to shape, they work well. I ordered Porsche ones.
Old Apr 8, 2024 | 01:41 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Do you need to remove the plastic covers from the holes before using these pads? Or they can stay in place?
Old Apr 8, 2024 | 01:53 PM
5 Year Member
Yes you need to remove the plastic covers. I used some modeling clay and pushed it up to make a template and then cut the Porsche ones down and they fit right inside those holes just like the ones from HMS precision. Not a pretty as his but they work well.
Old Apr 8, 2024 | 02:39 PM
EJ_Rapide's Avatar
Thank you.
Old Apr 9, 2024 | 10:57 PM
Jorgens's Avatar
Ordered from HSM :-) Thanks!
Old Apr 10, 2024 | 05:32 AM
Spdrcrj's Avatar
Spdrcrj is infamous around these partsSpdrcrj is infamous around these parts
I have a set of Tesla jack pads. I cut the “guide” off and now it’s just a hockey puck. Worked well when I installed the secondary cat delete pipes.
Old Apr 10, 2024 | 07:28 PM
ram_g's Avatar
5 Year Member
ram_g
I just use the big rectangular rubber blocks that came with my QuickJacks. The sill plastic is very robust and does not crack even if the rubber blocks overlap it a bit. Honestly I think getting something custom fitted is over-thinking things a bit. I very highly doubt that any service shop, including the AM dealers, use anything other than the typical rubber blocks that come with their lifting equipment.
Old Apr 10, 2024 | 07:44 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I like using the HSM Precision pads with my Quickjack. It makes it really easy to line up the pads with the rubber blocks for a secure and safe lift.
Old Apr 14, 2024 | 04:18 PM
MRCW's Avatar
I used to do this but found that at the jack points is where the front wheel will liner also attaches... so i use the pucks when I have to remove them
Old Apr 14, 2024 | 04:50 PM
ram_g's Avatar
5 Year Member
ram_g
Yes, you’re spot on. I’ve noticed this and scratched my head on how to remove the wheel well liner when the time comes (I haven’t had to do that yet). I also have a 4 post lift so currently my tentative plan is to undo those fasteners while on the 4 post, and then bend the liners away slightly to lift the car on the QuickJacks. We shall see…
Old Apr 15, 2024 | 04:59 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Hockey pucks. No overthinking needed.
Old Apr 16, 2024 | 12:13 AM
Jorgens's Avatar
I actually had the same thought initially..😄
navalarch
Sep 26, 2012 06:18 PM
Best4u
Garage Forum
15
Aug 5, 2012 08:12 AM
crazy1323
Garage Forum
16
Oct 15, 2009 02:31 PM
silver911
Garage Forum
Jul 14, 2009 09:23 AM
Morgie
Jan 17, 2006 01:25 PM
