DB-9 primary cat delete,has anyone done it in USA?
Old Jun 22, 2024 | 08:40 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Hi
I am planning to get primary cat delete done on my 2009 DB9.
I just recently watched video by Mike from BR and it scarred the hell out of me how ceramic from cat can get sucked in to the engine
has any one done this in USA any DIY or any mechanic resource who can do it for me
I am in Florida
Old Jun 22, 2024 | 09:10 PM
SloMoShun's Avatar
SloMoShun is infamous around these partsSloMoShun is infamous around these parts
This kit deletes the primary cats and also replaces the secondary cats with less restrictive units. The primaries are the ones you are worried about.
https://www.velocityap.com/product/a...17-power-pack/
Old Jun 22, 2024 | 10:26 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
A different approach (don't know if it costs less):
And this: https://www.6speedonline.com/forums/...elete-v12.html
Old Jun 23, 2024 | 08:07 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
I had the Velocity system installed on mine earlier this year. Make sure you do your research on a primary delete. The headers and high flow cats *significantly* change the sound of the car. In my opinion, the primary delete is only part of the mods required for a complete upgrade. I'm looking at modifying the high flow cats with an additional resonator to tone thing down a bit.
Old Jun 24, 2024 | 06:10 AM
embdenb's Avatar
Saw a video where the owner removed the exhaust manifold. Cut an opening in the side, removed the catalytic material and welded the opening back up.
KiwiStu
Jul 1, 2023 12:25 PM
GB9Garage
May 14, 2023 12:17 PM
gtmule
May 6, 2021 07:42 PM
All Mack
Apr 24, 2017 01:50 PM
