V8V 2015: Common sources for road surface related Buzz from dash area?
Old Oct 13, 2024 | 09:17 AM
Phil_rae's Avatar
Phil_rae is infamous around these parts
Is there a notorious cause for a low frequency buzz that comes from the dash area of the 2011-2017 range of V8V when going over rougher asphalt? It sounds like a heat shield or similar and appears to come from the passenger side if sitting in the driver seat and vice versa when sitting in the passenger seat. I guess therefore it is a noise maker resonating inside the dash or firewall area.
No issues on smooth asphalt, only rougher textured asphalt which cause the loud buzz. I can prod around the firewall and under the car looking for something loose, but I just thought I would enquire here in case there was a notorious trouble maker.
Philip
Old Oct 13, 2024 | 04:07 PM
Phil_rae's Avatar
Apparently solved
Since the buzz has gone, it must have been
1) the fuze box in the engine compartment banging a sort of plastic wheel well cover that resonates. A small bit of sticky foam pad eliminated the play.
2) the aluminum heat shields in the primary/secondary cat region being too close to the chassis and transmitting vibration from the isolated shield to the main body of the car. A small bend was easy.
I suspect the latter, but cannot prove it.
Philip
jibstyle
Nov 27, 2024 09:36 AM
sixgun95
Jun 2, 2013 12:47 PM
advantyper
Dec 8, 2012 09:44 AM
Eric (Plug Guy)
Dec 10, 2009 06:48 PM
invids
Mar 23, 2009 09:36 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
