Alternate way to open gas "door"
Old Nov 12, 2024 | 09:50 AM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
2005 DB9. What to do if the button does not release the gas door? I had a bad dream about this. I'll spare you the details. I would think there is another way. Thanks in advance.
Bob D.
Old Nov 12, 2024 | 10:04 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
What I do when it happens is I go and "massage" the fuel door towards the front, to give it more clearance before I push on the button.
It usually does the trick.
Then you'd need to rework the fuel door, there is a TSB about it.
I believe there is a way to open it from the inside of the trunk as well?
Old Nov 12, 2024 | 01:26 PM
deckman's Avatar
Inside the trunk remove the panel near the rear. There is a cable to pull that releases it manually, but you will still probably need to fool with the lid while you do it.
Old Nov 12, 2024 | 03:01 PM
M32's Avatar
M32
M32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond repute
Bob D.
On my 07 ventage, open the trunk, take off panel on the left side and you will see this plastic/glow in the dark color tab you can pull. That's how I've been gassing mine up for the last couple of years
Edwin
Old Nov 19, 2024 | 06:36 AM
Verg's Avatar
Verg
There are videos on Youtube for various fixes. If pulling the emergency release in the trunk does not work, taking a business card and levering up gently + pulling the emergency release normally pops the door up. Seems like there are a few failures for the doors: misaligned door catching on the body(re-align at hinge), door flap solenoid weak(lube or replace), and door springs weak(replace springs).
randyb
Jun 20, 2025 01:23 AM
DrScoles
Apr 17, 2015 06:01 PM
zuman
Nov 25, 2014 10:28 AM
Bodessem
Oct 22, 2014 08:35 PM
