Suspension parts - Alternatives
Old Jan 22, 2026 | 09:58 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Would you swap the ball joints on those control arms along with the 2 bushings? Or do they resist much longer than the bushings?
Old Jan 22, 2026 | 11:03 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Originally Posted by EJ_Rapide
How do suspect you might need to replace the shocks? Are they leaking? Or just not traveling back and forth correctly?
I feel like my FR shock is going out (smaller tire clearance VS the FL), but I don't know if this maybe could be caused by the slope on my driveway...
Shocks have been leaking since forever. Was never enough to be really concerned until now. Mechanic says shock tower mounts are a bit loose. Also said the shocks tend to last about 50K which I am 54K.
Looking to do a general suspension refresh. Replacement shocks are really pricy. Looking at ~10K from the usual AM part discounters in UK. Mechanic looking to see if he can find less expensive or possibly rebuild them.
Old Jan 22, 2026 | 11:05 AM
5 Year Member
Not sure just yet.
Old Feb 7, 2026 | 11:07 AM
EJ_Rapide's Avatar
Just received the bushings kit for the lower arm... Now thinking I should get the kit for the upper arm as well and do the full refresh.
Sway bar bushings, sway bar links and hardware coming in from Europe.
Next step is finding a place that can rebuild the struts before I dive into the full process.
Old Feb 8, 2026 | 11:23 PM
Spitfire980's Avatar
Spitfire980
Do you have the link for the ball joints?
Old Feb 9, 2026 | 12:50 AM
EJ_Rapide's Avatar
Got them off the flea bay... https://www.ebay.com/itm/375746375572?
Old Feb 9, 2026 | 08:10 AM
5 Year Member
I've bought oil and cabin filters from the same seller.
VAGscum
Sep 19, 2013 03:56 AM
RobbC
May 15, 2012 05:48 AM
Steve Germany
Mar 2, 2009 01:21 PM
waymegelli
Aug 26, 2008 10:08 AM
