2007 DB9 V12 Engine builder manual
Old Dec 10, 2024 | 06:57 PM
SinisterSF's Avatar
5 Year Member
SinisterSF is infamous around these parts
I have 2 2007 db9s I want to do engine rebuilds on. Does anyone have a part number list for engine rebuilds? Bearings, rings, bolts, etc. Also a service manual that details all the engine specs and assembly procedures?
I plan to tear the motor down and have it all cleaned and resurfaced but I want to check specs to make sure I can reuse the rotating assembly.
Old Dec 11, 2024 | 06:47 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
@AM4884 might be able to help you out. He's the only one recently that I know of on the forum that's done it.
Old Dec 11, 2024 | 07:01 AM
SinisterSF's Avatar
5 Year Member
I reached out, hopefully he’s still active.
Old Dec 11, 2024 | 10:42 AM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
You may want to check out Pistonheads AM forum, more likely to find information over there.
Old Dec 11, 2024 | 08:51 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I PM'd the old thread
https://www.6speedonline.com/forums/...-2006-db9.html
A fun motor and worth the effort. I collected some information in an excel, but most of it is in the thread. I'll look at scuderia and see if I can get a list of invoices. Those are the parts that I had to buy for a AM. In particular - the oil cooler/heater. You can't clean one after the engine spews bearing bits. So I bought a new one... Ate hotdogs for a month after that purchase!
Old Dec 18, 2024 | 04:05 AM
KianFord's Avatar
KianFord
Thank you so much for the information.
Spoiler
Old Dec 18, 2024 | 04:37 AM
AM4884's Avatar
5 Year Member
Happy to be of help!
GB9Garage
May 14, 2023 12:17 PM
Pigdog
Jan 17, 2017 05:58 PM
23546ghhga99
Mar 31, 2015 09:27 PM
XWCGT
Nov 11, 2013 08:27 PM
BlackCobra
May 26, 2010 07:37 PM
