Squeaky rear suspension on V8 Vantage S
Happy Friday everyone. Trying to solve another issue on the 2012 V8 Vantage S I got last week. When driving on city roads or any minor bump in the road, the rear suspension sounds like I’m having passionate love on an old motel bed. I’m talking VERY squeaky. Like I’m walking around an old haunted castle with wooden floors. The previous owner installed coil overs.
Anything I can do to remedy this at home with a basic tool set and some grease? It’s pretty embarrassing to bring passengers along to see my shiny new toy and it immediately sounds like an old sh*tbox
I have a similar noise. My mechanic tells me that it is from the bushings in the suspension. Mine is a 2014, our cars are 11 and 13 years old. Makes sense that some rubber would be worn by now. I'm going to replace my bushings when I replace the suspension. Already dreaming about that
HelloThese are simply the silent blocks for the rear upper wishbones, on the body side. Simply remove these two axles, lightly grease them, and reassemble. Tighten to 11 mkg.
Be careful to tighten the suspension under stress (as if the wheel were on the ground / raise it halfway with a second jack under the hub, before tightening)
Most likely its control arm upper bushings, mine had same issue from day one, mostly when it was cold. replaced with polyurethane bushings (myself) noise is gone. I have BC coil overs too,
Which bushings did you go with?
Soooo my V8V GT had the horrible squeak from the front control arm bushings. I was advised against the powerflex bushings even though I had already bought them. My indy shop pushed out the old bushings, trimed them, relubed them and reinstalled them and the noise has been gone since. I think it was about 5hrs of labor total.
