Copper washer for 4.3………
Old Mar 1, 2025 | 08:57 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
I am getting ready to do an oil change for the season. But I was wondering on the size of the copper washer for the oil tank. I have gone to all the local auto parts stores and they don’t have an exact match. Could you let me know? Thanks.
Old Mar 1, 2025 | 01:12 PM
Percy Penguin's Avatar
Percy Penguin
Hi - the Aston Martin OEM part is 1 inch (OD) by 5/8 inch (ID). But it's quite a loose fit on the plug, so I don't think it's essential to get exactly this size - the nearest you can get will probably be okay.
Old Mar 2, 2025 | 07:06 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
DORMAN 097-138 still available from RockAuto
Check out post #114 for details on the copper washer and other consumables:
https://www.6speedonline.com/forums/...-change-8.html
Old Mar 2, 2025 | 03:25 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
at some point I bought a aluminum washer kit & copper washer kit from amazon. Assorted sizes in quantities that my future grand kids will appreciate... Has solved this problem a number of times.
Old Mar 2, 2025 | 04:40 PM
Argus's Avatar
Thanks. I looked for this post but never could find it.
Old Mar 2, 2025 | 06:39 PM
DonL's Avatar
Don't know why you couldn't find it...
Aug 7, 2016 | 03:17 PM
Share
#114 Add to DonLs Reputation
@DonL
@DonL
Flat Copper washerQuote:
Originally Posted by blue2000s
I've seen alternatives for the drain plug, the o-ring and the oil filter. How about the copper washer? Is it just a flat washer or does it have a special profile?
Although it's not an exact replacement, I've been using Dorman #097-138 as a substitute for the AM OEM copper drain washer on the dry sump oil reservoir on my 2007 4.3 Vantage.
DORMAN -097-138: Metal; Size; M14; Inside Dia: 0.61"/15.6mm;
Outside Dia.: 0.94"/23.9mm; Thickness: 0.079"/2mm
AM: OD = 1.0"/25.4mm ID: 0.64"/16.25mm; Thickness (used):0.57"/1.45mm
Since the substitute is a bit smaller on the OD, you have to take a little care to center it when installing. Use at your own risk.
Oil Drain Plug: Dorman 090-115: M14-1.5 w/13mm hex
Both are available from rockauto dot com: The copper washers are sold in a box of 10 for less than $10 + s/h ($0.94 each).
The drain plug is less than $3 + s/h.
I normally just replace the drain plug gasket rather than the whole assembly, as the metal part doesn't usually wear out .
You can see the gaskets in the bottom of the photo; but I can't, at the moment, remember where I sourced them...senior moment I guess?
I suspect any good auto parts store can supply 14mm ID oil sump drain gaskets, if you choose to go that route (as well as M14-1.5 drain plugs at a cost less than AM charges).
The availability of the copper gaskets might be another story...
Current price on rockauto has increased by $0.03 each. Still a bargain.
Old Oct 26, 2025 | 07:59 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
maybe these rubber seals Ford m14
Amazon Amazon
Duckstu
Jul 28, 2017 01:50 PM
Heima996C4S
Sep 23, 2012 06:52 AM
ncmavro
Aug 10, 2011 08:10 PM
Cattman
Jan 18, 2010 07:42 PM
jrho
Aug 21, 2009 12:39 AM
