Headlight Lens Restoration
Old Apr 2, 2025 | 11:28 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
I wanted to ask around before I tackle this. For 2013 or newer with single lamp style.
I don't want to do something stupid and mess up the headlight lens.
I have one that is becoming discolored and a small bit of clouding.
I have felt around for any film but cannot detect any.
Is this safe to do a normal headlight polish?
Old Apr 3, 2025 | 05:13 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
There IS a film, if you try to peel it off it will ruin your whole day. Rich, at Redpants, has a post regarding trying to peel that off and the results...
Old Apr 3, 2025 | 05:59 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I have those marks on my headlamps too. One is much worse than the other. I may replace to worse off one with a new headlamp.
Old Apr 3, 2025 | 03:29 PM
TonyN923's Avatar
TonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the rough
You can completely remove the film, sand, polish, and other clear coat or PPF over it
Old Apr 4, 2025 | 09:40 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Ah! Subscribing to this thread as this is my next project.
Old Apr 4, 2025 | 09:41 AM
EJ_Rapide's Avatar
So wait, can we remove the film or not?
Old Apr 4, 2025 | 10:03 AM
AM-DB9.2's Avatar
That's the million dollar question, and any difference between Gen 1 and Gen 2 cars?
Old Apr 4, 2025 | 11:39 AM
EJ_Rapide's Avatar
How can you detect if there is a film or not?
Can you just polish the film? Or that will make it worse?
Old Apr 4, 2025 | 12:16 PM
TonyN923's Avatar
Headlight film removed, polished, automotive clear coat and then ceramic coated. Only do this if it's bad because it does take alot of work.
Old Apr 4, 2025 | 12:21 PM
EJ_Rapide's Avatar
Looking nice!
How bad was it to remove the film?
Did you remove the headlight off the car?
Old Apr 5, 2025 | 03:04 PM
EJ_Rapide's Avatar
This is what my headlights look like
So yeah, any advice is appreciated
Old Apr 5, 2025 | 10:43 PM
TonyN923's Avatar
headlight restore can do it on the car. All depends on who is doing it.
The Vantage is a bit overboard. Sand, polish, clear, PPF, and finally ceramic coating
The Viper did not get clear coat. PPF then ceramic coating
Old Apr 6, 2025 | 07:16 AM
embdenb's Avatar
Apparently no one on this list has restored their headlights themselves. And no one knows for sure whether these headlights have a film or not. Contact a professional headlight restoration company for advice.
Old Apr 6, 2025 | 09:06 AM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
My new 2014 Vantage had a factory coating per Galpin. It was ruined by my PPF installer, who apparently got an alcohol-based substance on the lenses. I self-restored with the wet sanding and liquid restoration process ( a kit from Amazon...many available ). No problem with residual coating but, as others have said, a bit nerve racking. The sanded opaque lense clears right up with the final step of liquid polish. Lasted for many years and then I had a professional clear them up again for ~$200. One caveat...the lenses can develop micro-crazing on their interior side from headlamp heat over time. An exterior polish will not address that.
Also, Expel and others sell pre-cut headlight film.
Old Apr 6, 2025 | 02:45 PM
TonyN923's Avatar
I would just have a body shot sand it down and clear it, if there is a coating or something over it, its already done for anyways. basically your just removing all the failed film, smoothing it out and putting a clear coat over it.
If you want to do it youtself, buy a kit that attaches to your grill and sand away. I would buy a precut PPF after your done polishing and ceramic coat it after and you should be good for a long time.
