aftermarket door and hatch struts?
Old Oct 18, 2025 | 09:12 AM
MRCW's Avatar
2009 V8 Vantage - door and rear hatch struts starting to fail... again...
anyone had luck with aftermarket struts? maybe even with some more force?
these OEM ones only lasted about 3 or 4 years...
I have some on my BMWs that have lasted 10 plus years...
Old Oct 18, 2025 | 02:27 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I am looking at red pants …89$+ for a pair of door struts..
Old Oct 18, 2025 | 04:18 PM
MRCW's Avatar
I bought these last time... not again if I can help it
Old Oct 18, 2025 | 07:21 PM
Import's Avatar
Interesting..and good to know…
Old Oct 19, 2025 | 04:45 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
On my DB11, the door struts and the boot struts were worn out.
Purchased the door struts from Redpants and they worked/still work fine, over two years now.
On the trunk struts, I spent some time comparing the originals to struts available on one of the popular sites that sell by the size (length/travel), pressure. and end connectors. I got close the first time but not enough pressure. The second time I ended up over pressure making the trunk a little hard to close (trunk is a soft close so only need to get it close to the latch). After two years now, these are still working and getting lighter for the close as they wear. In this case, I ended up buying twice with one set that didn't work but cheap enough it really didn't matter to me.
Old Oct 19, 2025 | 07:01 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Check out earlier post with several alternatives...
https://www.6speedonline.com/forums/...acement-3.html
Old Oct 19, 2025 | 09:47 PM
Jano4's Avatar
Jano4 has a spectacular aura aboutJano4 has a spectacular aura aboutJano4 has a spectacular aura about
I recently installed a pair from LIftSupportsDepot on the doors and hood of my 2014 DB9. They installed without any issue but they have more force. Instead of holding the door at "nearly" any position like OEM, when I open the door close to half way, the pressure wants to open the door fully. Better than what I had as the originals no longer held. I've been wanting to contact Liftsupports though and get there opinion.
Old Oct 20, 2025 | 03:20 AM
Spitfire980's Avatar
Spitfire980
Did my hood struts on my 05 DB9 from LIftSupportsDepot
Old Oct 20, 2025 | 06:38 AM
MRCW's Avatar
I'm going to reach out to them this week...
Old Oct 20, 2025 | 12:53 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Anyone know about an aftermarket door struts for 2007 Vantage v8?
Old Oct 20, 2025 | 01:35 PM
J doubleU's Avatar
I got some off ebay, definitely stronger than OEM ones as you need to check your surroundings as to not do any damage.
$50 for the pair.
Old Oct 20, 2025 | 01:47 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
Hatch Struts: Boxi 6393
Installed a set of these on my 2009 V8V and they work better than the Aston units.
Boxi has door strut units too.
Old Oct 20, 2025 | 02:55 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
lift support depot from Amazon on my 2009 V8V work fine for hood and hatch
Amazon Amazon
and
Amazon Amazon
Old Oct 20, 2025 | 08:45 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
The biggest downer on the cheap struts is they're black. I think the minimum requirement for me would be for the tubes to be silver. I know it's a small thing, but it really makes things feel more special. I managed to find a set of silver trunk struts a while back for small discount over the factory ones. They're easily mistakable for the originals as they're only missing the AM light-blue printing. Unfortunately I'd peeled the labels off of them so there's no indication where they came from. I'll look a bit for the order and update if I find them.
(edit) The struts were also from Lift Supports Depot. That's the same manufacturer as the same as the amazon link above. The part number for the DB9 coupe silver trunk struts is PM3847-a. $36 for a pair on Amazon. LSD makes them for all positions of our cars. The Aston struts have a slightly brighter polish, but if you weren't holding them side by side you'd never know they were aftermarket.
Old Oct 21, 2025 | 07:21 AM
DonL's Avatar
Photo of LSD hood struts vs: OEM from June 9, 2024 posting
Hard to tell from original...
