aftermarket door and hatch struts?
Old Oct 21, 2025 | 11:43 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
That doesn't surprise me in the slightest. LSD also lists Stabilus air strut parts on their website which are the OEM for the factory parts. I'd almost bet money they're exactly the same minus the blue AM printing directly on the tubes.
Old Oct 21, 2025 | 03:04 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Tbh..wouldn’t mind a little more lift on the tailgate…mine is a fingernail breaking lift..although it stays no probs..
Old Oct 21, 2025 | 07:22 PM
MRCW's Avatar
I reached out to LDS for actual door strut specs
Here are the specs for these lifts. PM3520DExtended Length A [in]: 10.24Compressed Length B [in]: 6.61Stroke C [in]: 3.63LBS in Force: 103 LBSShaft Connection: Ball Socket U Band (Nylon)=10mm=3/8"=.39"Body Connection: Ball Socket U Band (Nylon)=10mm=3/8"=.39"SKU: PM3520D-W PM3777= 56 lbsExtended Length A [in]: 10.24Shaft Connection: Ball Socket U Band (Nylon)=10mm=3/8"=.39"Body Connection: Ball Socket U Band (Nylon)=10mm=3/8"=.39"LBS in Force: 56 LBSSKU: PM3777-W Have a wonderful day!======================Lift Supports Depot Customer Service(866) 969-5438
Old Oct 22, 2025 | 06:14 AM
Mark Gronsbell's Avatar
Mark Gronsbell is infamous around these parts
When I replaced the struts on the doors and trunk a few years back, I do not recall the prices for OEM being that costly. Unless this has changed, why bother going aftermarket?
Old Oct 22, 2025 | 07:13 AM
GA_DB9's Avatar
5 Year Member
I'm with you there, Mark. I replaced my trunk struts with the LSD stainless at a time when it was hard to get them. Recently I did the the door struts with the factory parts and while they were 3-4x the cost of aftermarket, they still weren't that bad. Some owners want to minimize the maintenance cost at all costs and sometimes parts can be hard to find. It's a personal decision.
Old Oct 22, 2025 | 07:18 AM
MRCW's Avatar
I'm trying to improve on the OEM...as I've looked into this, the after market ones for my doors I ordered appear to have a higher weigh/lift capacity...
besides who wants to pay bespoke Aston Martin prices for the same parts...AML cars are loaded with the same parts used in Ford, Volvo, etc... at a significant cost savings than AML prices
Old Oct 22, 2025 | 05:39 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Are those parts for a first gen Vantage? The numbers come back for a DB9.
Old Oct 24, 2025 | 05:03 AM
MRCW's Avatar
I think they are the same. I ordered them so when they get here and install ill let folks know the result
Old Oct 26, 2025 | 08:26 AM
Argus's Avatar
Just a quick FYI. According to Redpants the Vantage and DB9 use the same door strut.
IJWS
Sep 27, 2023 05:11 PM
RDroz
Mar 8, 2023 06:17 PM
Kalepsis
May 31, 2020 10:37 AM
shinjuku
Jan 7, 2016 09:08 AM
mark higinbotha
Jan 31, 2012 11:33 PM
