My 2008 Vantage Progress Thread
Old Nov 24, 2025 | 02:05 PM
  #46
MRCW's Avatar
I also opted for Continental AS tires... although mine are 20"... had the U H P Michelin but very harsh with 20's and the Sport Pack set up on my Vantage.
Old Nov 25, 2025 | 04:09 AM
  #47
rushilkumar27's Avatar
rushilkumar27
Originally Posted by sirhodjibob
Hello all,
I purchased a 2008 V8 Vantage on BaT a few weeks ago and will document maintenance and updates here. I generally DIY, so enjoy my trials and tribulations.
The car is Midnight Blue over Sahara Tan, and is a Sportshift model. I've been a manual guy for a long time, but thought this might be an interesting new experience. So far I am enjoying it.
Cosmetically it looks to be in really nice shape, with the only let down being the typical leather pealing on the dash and cracked wood trim. Mechanically, it runs well with no warning lights, but I'm going to fully reset the maintenance clock on this to give a starting point. It has some of the common foibles which I'll get into later.
Congrats on the new V8 Vantage — what a fantastic pick! Midnight Blue over Sahara Tan is an absolutely classic combo, and the car looks great despite the usual dash leather and trim quirks. Sportshift definitely takes a little adjustment compared to manuals, but it’s still a fun and engaging setup once you get used to its rhythm. Smart move doing a full maintenance refresh so you know exactly where everything stands. Looking forward to seeing your updates and DIY adventures — enjoy every mile with that V8 soundtrack!
Old Nov 26, 2025 | 10:18 PM
  #48
sirhodjibob's Avatar
sirhodjibob
Thanks all. The Continental DWS is a great all season tire, but a more aggressive summer tire is what I am going for here, especially given the dry climate.
Installed:
6G43-07-10056-PK x 2 - spark plugs (pack of 4)
9G33-12A366-AA x 8 - coilpacks
Torque for spark plugs is 20-30nm (not 16-20, like a popular DIY blog says...), coil pack bolt is 5-7nm.
And yes, you can get a torque wrench on the rear most spark plug. No wobble extension needed. Remove the strut brace (it's 4 bolts) and disconnect the brake pressure sensor plug.
Old Nov 26, 2025 | 10:29 PM
  #49
sirhodjibob
2 bits of basic maintenance left- replacing the power steering fluid and those pesky ASM hoses + hydraulic fluid. Will flush the coolant too for good measure
Old Dec 7, 2025 | 07:12 PM
  #50
sirhodjibob
If you haven't removed the lower cover under the radiator recently...you may want to take a look. I think I cleaned out about 2lbs of leaves and bugs.
Installed Bosch Icon wiper blades as well. I'm sure many of you know the trick, but hold buttons 8 & 9 in the center stack and key on. Not pictured but I picked up a set of wiper arm nut covers from a facebook group
Old Dec 7, 2025 | 08:11 PM
  #51
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Would those wiper arm nut covers fit other models than the Vantage?
Do you maybe have a link to the group?
Thank you.
Old Dec 7, 2025 | 08:14 PM
  #52
sirhodjibob
I believe they do- my understanding is the wiper arms were updated with the last refresh of the Vantage and similar (same?) as DB9. Would recommend cross referencing the part number
Facebook group is Aston Martin DIY: https://www.facebook.com/groups/amdiy, guys name is Dan Sharp
Old Dec 8, 2025 | 02:03 PM
  #53
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Do you not need amds to do the asm hose bleed….
Old Dec 9, 2025 | 07:28 AM
  #54
Exposer's Avatar
Exposer
Watch out these are pretty infamous for clutch issues that pop up early. get that checked ASAP. And while you're at it the timing cover gasket's another weak spot to keep an eye on.
Old Dec 9, 2025 | 12:51 PM
  #55
VantageAston's Avatar
VantageAston is infamous around these parts
Lol, are you trying to start an argument? Go on, tell him that it's an engine out job too
Old Dec 9, 2025 | 01:14 PM
  #56
Yes you do.....
Old Dec 9, 2025 | 02:29 PM
  #57
mrtzmd's Avatar
mrtzmd is infamous around these parts
You do not need an AMDs to bleed the asm hoses. My BMW mechanic changed my asm hoses on my 2008 SS and bled the system with his scanner. The hydraulic system is the same as a similar year BMW m3.
Old Dec 9, 2025 | 05:42 PM
  #58
Import's Avatar
Interesting…mine are going to need changing soon…but I was convinced it was a dealer job..will my foxwell nt530 do it…
Old Dec 9, 2025 | 07:23 PM
  #59
My local indy said you need ADMS to do the bleed too......?
Old Dec 9, 2025 | 07:33 PM
  #60
Import's Avatar
That’s slightly confusing then…lol
