2018 Vanquish S with 40k miles. 3 repairs needed not covered under warranty. Help pls
Old Nov 29, 2025 | 11:00 AM
BrntRubber's Avatar
5 Year Member
BrntRubber is infamous around these parts
Hi All,
I have a Vanquish S with an extended Aston warranty in Dubai, UAE.
They are doing the following fixes under warranty:
1. Washer tank – leaking
2. Both door gas struts – weak
3. Plug cap – leaking
However they said the following also needs fixing and is outside of the warranty:
Parts & Labor Jobs (Including VAT)
1. Replacing drive belt (cracked) – AED 1,350 ($370 usd)
2. Replacing front lower arm with bush (cracked), assembly for left & right suspension – AED 25,263 ($7000 USD)
3. Replacing front wheel arch left & right (broken) – AED 6,690 ($1821 usd)
Total: AED 33,303 ($9,000 usd)
This seemed like very high costs and I wanted to get advice, especially item 2 the suspension issues. I think it is possible for a non Aston garage to just replace the bushes and not the entire assembly? Any advice on this? I also have velocity ap lowering springs that have not been fitted, so I was thinking that it might be better to find a good garage to replace the bushes and fit the springs.?
I know very little about suspension parts and dont want to make a bad decision. Advice is much appreciated. Thanks
Old Nov 29, 2025 | 12:39 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
There's a vendor on eBay that sells the control arm bushings. You can replace the bushings for way less than replacing the control arm itself. What does the dealership and/or indy garages charge per hour in UAE?
If the control arm itself is cracked, perhaps you can find a used arm and replace the bushing?
Old Nov 29, 2025 | 12:52 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
You are being ripped off/robbed.
See ====> http://www.astonmartinbits.com/model...2-18/parts/945
Search for your parts at www.astonmartinbits.com
The bushing company is Powerflex Bushing. They make a variety of bushing, if you choose to insert new bushings into you control arms.
Old Nov 29, 2025 | 04:38 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
I got quoted by an Indy in SF Bay $4,500 to replace the 2 front lower arms... so $7,000 by the dealer seems about right
Old Nov 29, 2025 | 10:44 PM
BrntRubber's Avatar
5 Year Member
Very helpful, thanks!
Thanks, I think its just the bushings that are damaged.
I will check the hourly rates and come back to you.
Thanks everyone!
Old Nov 30, 2025 | 07:01 AM
5 Year Member
The dealership will only replace the whole control arm; they won't replace the bushings unless you are friendly with the service manager.
Tomp
Nov 29, 2015 07:02 PM
irvineboy
Jul 8, 2013 11:03 PM
CTP855
Jul 8, 2013 10:14 PM
izzy025
Mar 28, 2009 05:23 PM
qfix
Jul 11, 2006 11:05 AM
