DB9 Center rear lift point
Old Dec 22, 2025 | 12:40 PM
jnance50's Avatar
jnance50
Hey guys, the workshop manual lists a center lift point for the front in the form of the front subframe rail, which I have successfully used. I’ve read about some shops using a similar center lift point in the rear, but I cannot find it officially in the workshop manual. Does anyone know of a safe center lift point for the rear? I’m going to pull the plastic cover panel when I get home and have a look. I still have the front of the car on jack stands on the factory side lift points, I’d like to raise the rear from a center lift point and put stands under the side lift points to have all 4 corners off the ground.
Old Dec 22, 2025 | 08:56 PM
J doubleU's Avatar
I would consider using ramps at the rear, stands could be crazy dangerous if your lowering the front subframe and supporting the engine for manifold removal. Where are you located at?
Old Dec 23, 2025 | 02:43 AM
jnance50's Avatar
jnance50
For the headers, I do have a couple of friends coming to help, one of which is bringing a set of quick jacks. I already have the jacking pads specific for this car that I picked up from AstonUpgrades, I’m thinking that’s all I need in order to use those? However, they won’t be available for a week or two due to the holiday and in the meantime my car is just sitting with front wheels + liners out. So, I had thought while I was waiting I might lift the rear and do the trans and diff service.
I’m located in north central Alabama. The friends that are coming to help are both seasoned mechanics, but neither have worked on an Aston previously.
Old Dec 23, 2025 | 12:01 PM
J doubleU's Avatar
Sounds like your sorted out, I've just heard and seen a few stories of 4 jack stand lift failures. Good luck with your replacement.
Old Dec 23, 2025 | 12:31 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Aston1936 has plenty of how to do videos available.
Old Dec 23, 2025 | 06:26 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
NO jack stands....period !
anton28
Dec 13, 2015 08:02 PM
sdekoning
Sep 24, 2014 06:28 PM
kitw
Jul 28, 2013 03:05 PM
bad107
Jul 31, 2011 12:59 AM
