Fuel Door Cable
Old Jan 16, 2026 | 10:59 AM
AAROND81's Avatar
AAROND81
Fuel Door Cable
I'm a new owner getting acquainted with my 07 V8V. I purchased it knowing the fuel door didn't work and that it was a common problem. My fix was different than the door alignment or actuator that most other people experience. The actuator tried to move when I pressed the button, but it didn't move enough to release the door. My solution was a new cable. The old one somehow rubbed and rusted and it took a lot of force to pull the metal cable through the outer casing, even when out of the car. I couldn't see the problem until I removed it. I tested the actuator by disconnecting the cable and the white part that connects to the cable moved a lot more than it did when the cable was attached. I purchased a used cable on eBay from a Rapide, and it is a direct replacement and moves much more easily. If your fuel door doesn't open I would recommend adding this to the list of things to check before ordering a new actuator or just living with using the trunk release.
Old Jan 17, 2026 | 05:16 AM
SteveRhodeIsland's Avatar
SteveRhodeIsland
The actuator on my 14 Rapide seems to work ok, but the fuel door does not open 90% of the time. Maybe it's the cable, thanks for this tip
xmaciek82x
Jan 21, 2017 10:25 PM
slicky rick
Jun 1, 2016 05:14 PM
DrScoles
Apr 17, 2015 06:01 PM
programmatore
Jun 16, 2013 03:31 PM
brumma
Jan 27, 2012 01:20 PM
