VH V12 Vantage quiet start?
Old Jan 26, 2026 | 09:18 AM
LμL's Avatar
LμL is infamous around these parts
I know some cars have this functionality. I am curious if my 2015 V12VS has a quiet start mode and how to do it?
Old Jan 26, 2026 | 12:46 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Quiet start up ! That would be blasphemy I believe.
Old Jan 26, 2026 | 02:34 PM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
I would like to thank the clever Dr Bez for this endearing feature of the VH era. A tuner may be of help, perhaps VelocityAP, or at least have an answer to if it can be done.
Old Jan 28, 2026 | 11:42 AM
Speedraser's Avatar
Speedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond repute
Ha! It doesn't. However, through the aftermarket you can install a switch that will enable you to keep the exhaust in quiet or loud mode regardless of RPM/throttle position, as well as the original automatic mode.
Old Jan 29, 2026 | 06:09 AM
handyman2009's Avatar
Veteran: Canadian Forces
I don't believe it can be quiet at start up as it use vacuum activated valves on the exhaust and the exhaust vacuum pump needs to run to create pressure to close the valves. Those valves are open by default and close only with vacuum pressure. Maybe on second start up they might be close as the pump might keep some pressure but definitely not on first start up
Old Jan 29, 2026 | 09:35 AM
MRCW's Avatar
what's a quiet start? I have straight pipes on my V8V and thy sound is glorious!
Old Jan 30, 2026 | 08:19 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Agreed. The wicked start up is a big selling point!
Old Jan 30, 2026 | 05:01 PM
a102768's Avatar
a102768 is infamous around these parts
I have managed to do a quiet start in my Virage a few times by pushing the accelerator flat to the floor and turning the engine over for a few seconds then starting it normally. It doesn't work every time and makes a reasonable amount of noise doing that anyway!
Even with the secondary cats removed, I don't find the car excessively noisy after the initial starting flare, as long as I don't enable sports mode and go easy on the accelerator as the car is very keen to change to a higher gear at quite low revs then.
Old Jan 31, 2026 | 01:33 AM
PhuketPaul's Avatar
PhuketPaul is infamous around these partsPhuketPaul is infamous around these parts
For a quiet start you need to install a 3 way switch - always quiet - stock - always loud
details below
https://db9s.com/aston-martin-3-way-switchable-exhaust-valve/
Old Jan 31, 2026 | 02:03 AM
AstonLive's Avatar
AstonLive
There was no factory-equipped "quiet start" option available on any Aston Martin models built on the VH platform. This feature can only be achieved through aftermarket exhaust valve control systems. The "dry start" (or dry cranking) feature was available on V12 models equipped with the Ford-derived ECU ("Spanish Oak"). However, the V12VS and the Vanquish from model year 2015 onwards use the Bosch ECU, which does not support the "dry start" option.
LμL
Dec 23, 2025 09:37 PM
Gene G
Nov 4, 2025 06:34 PM
Sir Rothschild
Feb 10, 2024 10:55 AM
got one
Apr 28, 2022 10:39 PM
Prefurbia
Jun 29, 2017 06:51 PM
