Sequence to Close Navigation
Old Mar 25, 2026 | 12:52 PM
bobby1432's Avatar
bobby1432
In my 2006 DB9, my navigation screen no longer works. However, it seems to want to stay open. I would be very appreciative if somebody could tell me the exact sequence of clicks with the little joystick that I need to make to choose Shut Down and have the screen and its cover close. Thanks!
Old Mar 25, 2026 | 03:11 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
It should start up to the warning text screen. Simply clicking "back" from there closes mine. If you want it to never open again, you can disconnect the video cable from the nav unit under the driver/rear seat. Don't disconnect the power or MOST fiber connector or the whole entertainment system will cease to function.
Old Mar 26, 2026 | 06:45 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
It sounds like the gears that allow the mechanism to fold down are binding or stripped, replacing them is pretty straightforward and there are kits at Redpants, Aston Martin Bits, and other places as well as youtube tutorials on the process. They aren't that expensive either.
Jamezilla
Feb 18, 2020 06:36 PM
K9COP
Aug 15, 2016 09:22 AM
cuddapah
May 14, 2015 05:21 AM
airbusdrvr
Apr 24, 2015 07:25 AM
jmargolese
Apr 13, 2013 02:40 PM
