Vacuum Pump
Old Apr 2, 2026 | 11:30 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Vacuum Pump
Quick question about the vacuum pump on our cars: what is its function? Is it solely controlling the opening and closing of the exhaust valves, or does it control any other component on the car?
Mine is fried, and I want the valves open at all times, so I pulled the fuse... but should I replace it anyway?
Thanks!
Old Apr 3, 2026 | 03:42 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
If you're talking about the pump behind the right-rear wheel, that's only used for the exhaust bypass valves. It's a basic Ford pump if you ever want it working again. Dorman 904-214 is a cheap replacement.
Old Apr 3, 2026 | 05:31 PM
EJ_Rapide's Avatar
Thank you for the confirmation, sir!
Old Apr 4, 2026 | 06:59 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I'd replace if you can and go with a CCCharger. Being able to close the valves when on the phone helps a lot.
Old Apr 9, 2026 | 06:15 AM
SBRapide's Avatar
SBRapide
New 2010 Rapide owner and loving it! Thanks for the added insight to the car and good to know there is a replacement pump out there should I need one. One of the first things I did was install the CCCharger switch. Agree it's a nice option. Just finished a 2000+ mile road trip through Shenadoah Mtns and the Outer Banks. It was good to have, although mine doesn't always switch back to ‘quiet’ mode right away.
EJ_Rapide
Jun 10, 2024 07:11 PM
porsche996tt_tpe
Jun 20, 2017 10:53 AM
V12Vantage
Jan 21, 2014 07:27 PM
dynamic gt2
Mar 21, 2010 10:58 PM
