The Tire Rack Introduces the OZ Alleggerita
Old Feb 27, 2010 | 05:41 PM
  #91
blown996's Avatar
blown996 is infamous around these parts
Originally Posted by damon@tirerack
A few more pics have come in recently.....
Damon, what color are those on the white GT3?
Old Mar 1, 2010 | 03:06 AM
  #92
Roffa's Avatar
Roffa is infamous around these parts
Hi Damon.
I planning to get a set of pss10 and wheels from tirerack, but need advice on what offset I should get for the wheels.
I have a 996 c2 narrow body and what a more agressive / nicer look.
What wheels /offset should I use?
Old Mar 1, 2010 | 06:31 AM
  #93
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
See my thread on rennlist. I have the offset that works best listed there in Damon's other thread on this wheel.
Old Mar 16, 2010 | 08:33 AM
  #94
damon@tirerack's Avatar
Moderator
On the narrowbody 996 a 40ET front wheel works fine too. Dep used that instead of the 53ET we list. Either work.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Mar 29, 2010 | 12:47 PM
  #95
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
how much difference is there between the Anthracite and Matte Graphite?
Old Apr 9, 2010 | 09:36 AM
  #96
obsessed's Avatar
obsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to behold
OZ Alleggerita for 997S track use
Just got mine for 2006 997S. Rear weights came in slightly lower than expected.
F 18 x 8.5 +53 offset 18.03 lbs. - Hoosier Wets 245/35-18
R 18 x 12 +68 offset 21.96 lbs. - Hoosier Wets 315/30-18
Look great in black with graphite centers.
Old Apr 9, 2010 | 06:56 PM
  #97
eclou's Avatar
got mine on
Old May 8, 2010 | 09:40 PM
  #98
C70Pete's Avatar
C70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these parts
18" sizes
Hi Damon,
can we use an 18x8 to mount a 235/40/18 (front) and 18x10 (rear) to for a 285/35/18 ? will those rim sizes work...? 1999 996 C2 coupe here...
Old May 23, 2010 | 07:50 AM
  #99
obsessed's Avatar
Bought another set for 18" R6s in 245/35-18 and 315/30-18 - awesome!
Now have 10 track days on 18" Allegeritas between the R6s & Wets - very pleased. I go up on curbing and no issues (I do avoid really rough ridged curbing).
If you use center caps on track DO NOT use the carbon fiber ones - apparently the carbon fiber disc is hot glued to the plastic part that snaps into wheel - after my 1st track session 3 of the 4 centers were missing the carbon fiber discs. The silver center caps do not have the same problem. Save the carbon fiber caps for the street.
My 19" (8.5, 11) Ultraleggeras in black are for sale, PM me if interested.
Old May 23, 2010 | 02:41 PM
  #100
BartN (TX)'s Avatar
BartN (TX) has a spectacular aura aboutBartN (TX) has a spectacular aura about
Hopefully others will get this advise sooned than I did! Oh well, there just track wheels.
Old May 23, 2010 | 06:33 PM
  #101
I've got around 8 days on my wheels. No issues with the carbon caps. Maybe you got a bad set.
Old May 23, 2010 | 07:07 PM
  #102
Jack667's Avatar
Jack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant future
Center caps are typically not recommended for track days. I think they used to recommend that you pull them off while in the tech line at the events I used to do up north years ago
Old May 23, 2010 | 08:17 PM
  #103
obsessed's Avatar
I probably brake harder...
Old May 24, 2010 | 05:13 AM
  #104
Do they take your wheels off at tech?
Old May 24, 2010 | 05:15 AM
  #105
Are you running 6 piston GT3 calipers, brembo floating rotors, MPSC's, stainless lines, GT3 ducts, pagid yellows, and Motul fluid?
No? Then I doubt it
