Bentley Continental GT/GTC/Flying Spur DIY Thread
  #226
Old 10-19-2023, 11:14 AM
TWL's Avatar
TWL
TWL is offline
TWL is an unknown quantity at this point
Thumbs up
Hello ​​​​​​@TWL,
There are actually two pumps, one for the headlights, and the other for the windshield, so the low pressure on both in the same time frame may be the result of another issue.
If both are having low pressure issues, I would look at what type of fluid you are using in the tank, as I had issues some time back with my A8L W12, I was using the orange rain x, and not only did it slow down the flow, but it coated the level sensor with a film that kept the sensor from sensing fluid, so I had a constant "low washer fluid" warning, so I put some hot water in to flush the system and sensor, well it worked, but I found that I actually had the water a bit to hot, and melted the tank at a certain level, so I couldn't fill to the top, lesson learned.
Pumps are numbers 9 and 10, and the assembly is located in the passenger side front wheel well, you could try some warm water to flush, or disassemble and clean the screen/inlet on each pump.
Johnny
Wow! Thank you so much.
  #227
Old 10-21-2023, 06:07 PM
glh's Avatar
glh
glh is offline
glh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud of
I might of posted this before but there are a ton of information related to frequent troubles, DIY, parts equivalent and so forth in this document.
https://drive.google.com/file/d/1zsAYOiEQHjRnUcDIdUoGzlhJRFvLqA4X/view?usp=drivesdk
Mars911
Bentley
07-09-2023 05:26 PM
Golf Addict
Bentley
34
04-12-2023 11:30 AM
Gianni Perrotta
Bentley
08-20-2020 11:25 AM
Big Carrot
Bentley
02-20-2007 04:27 AM
SLVRSL55
02-20-2006 02:12 PM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Bentley Continental GT/GTC/Flying Spur DIY Thread
