Surface rust on truck mech?
Old Jan 20, 2013 | 12:41 AM
jc_333's Avatar
jc_333 is infamous around these parts
Just noticed what seems to be surface rust on both sides of the truck mech?
Anyone else have this problem?
Old Jan 20, 2013 | 12:01 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
No. Does or has your car spent much time outside?
Old Jan 20, 2013 | 04:07 PM
chinaleeexports's Avatar
chinaleeexports is infamous around these partschinaleeexports is infamous around these parts
No rust on mine either.
Old Jan 21, 2013 | 03:17 AM
jc_333's Avatar
Spends most of its time parked up in HKbut I guess previous life in UK it was out and about more.
Rust seems to be coming from the two washers, will keep it a clean and update later.
Old Jan 21, 2013 | 07:04 AM
Where you live makes a big difference also. I recall owning a motorcycle in Ca and then moving to TN. The metal aged much more rapidly out here. Clean them well and dress with a hydrophobic compound.
Old Jan 21, 2013 | 09:29 AM
Wedgeduck's Avatar
Wedgeduck is infamous around these parts
I am a few blocks from the ocean and we get a little bit of corrosion because of the salt. Jc333 lives in HK on an island surrounded by salt water. Could be very corrosive. Use a good rust inhibitor. check if your trunk drain hoses have leaks or are not functioning.
Old Jan 21, 2013 | 06:48 PM
Neil Mccauley's Avatar
Neil Mccauley is a jewel in the roughNeil Mccauley is a jewel in the roughNeil Mccauley is a jewel in the roughNeil Mccauley is a jewel in the rough
Just goes to show, nothing lasts forever, not even Bentley trunk hinges..
Old Jan 23, 2013 | 10:26 PM
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
i sprayed every hinge on the car with a product called krown here in canada, its much thicker then say wd40, then i just wipe it off. keep them oiled. shouldnt rust if you do that
Old Jan 24, 2013 | 06:01 AM
jc_333's Avatar
Umm...rust seems to be coming from the gold washers on the mech. No such problem on my audi or mb which purchased in HK but will keep it a good clean and spray with silicone for protection.
whtrabt
Oct 5, 2015 05:23 PM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
TOGWT
Detailing
Sep 28, 2015 08:25 AM
