X pipe or h for conti gt custom job
Old Mar 20, 2013 | 11:28 PM
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
I just wanted a bit more bite from the exhaust so I was just going to have a shop chop out the resonator and 2nd cat as done in the mid pipe kits fabspeed and other companies sell
Just not sure if I should do an x or h
I did a x in my s550 and it made it too silent
Any suggestions?
Old Mar 21, 2013 | 04:00 PM
Wedgeduck's Avatar
Wedgeduck is infamous around these parts
Any suggestions?
I personally think that h or x doesn't matter. It's your stock mufflers you will need to change out too. Ask the Doc. I ran them both and on stock mufflers it hummed. On custom sports mufflers they sound quit exotic.
Old Mar 21, 2013 | 05:16 PM
SpeedwareMotorsports's Avatar
SpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to behold
X-pipe will generally flow better. The big thing will be the lack of resonators and cats will make for a louder note, but as Wedge mentioned, the mufflers really control the tone.
Make sure you use a good exhaust shop - cheaper builders generally use a crush-bender (since it is cheaper) and it will look and sound worse!
Old Mar 21, 2013 | 07:03 PM
REDNOSEGT's Avatar
my guy does stainless mandrel bent. proper work
but replacing the muffler with that valve i dont want problems after, I have read you cant just plug that valve to leave it open all that time it effects emissions and other stuff, not sure how true that is. I originally just wanted to plug the vac line so it stays open all the time. I dont always want to drive around in sport mode I dont like the way it revs and downshifts like that all the time.
Old Mar 22, 2013 | 09:35 AM
Wedgeduck's Avatar
My vacuum line is plugged. Can't tell you how it would affect your powerplant. The tuners can answer that question. Mine is just a wee bit on the high strung side. So the tuning on that ECU might need to be tampered with?
Old Mar 23, 2013 | 02:20 AM
REDNOSEGT's Avatar
Please read this and let me know what you think
https://www.6speedonline.com/forums/...st-valves.html
Old Mar 23, 2013 | 05:08 AM
ksbenz's Avatar
ksbenz is a name known to allksbenz is a name known to allksbenz is a name known to allksbenz is a name known to allksbenz is a name known to allksbenz is a name known to all
I want to pull the vacuum line as well and plug it, but am unsure if it will throw a CEL. I do not believe the info in that thread is all true although I am no expert. My friend has pulled the fuse on his AM Vantage and has no warning lights and car does not run richer.
Old Mar 23, 2013 | 09:24 AM
Wedgeduck's Avatar
Check engine light does not come on when you plugged the vacuum line. Go to my thread "ready to rumble" on page 8 on this forum. It's a video and sound clip. Do you want it to sound like this?
PenguiN
Oct 26, 2018 07:23 AM
993 Guy
Sep 4, 2015 07:48 PM
orbelo
Aug 30, 2015 12:26 PM
