Bentley Side View Mirror Puddle Lamp Bulb Replacement (pictures)
Old Mar 21, 2020 | 04:05 PM
  #31
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Holy crap, the mirror did not properly separate from the motor housing...
Pulled the gear shafts right out.
I take it that’s not good 🤣
Repairable or no?
Old Mar 21, 2020 | 04:22 PM
  #32
Johnny Hotspur GT's Avatar
Administrator
Repairable or no?
Try to separate the two sides, see the 8 clips, also are the gear shafts broken/snapped at the ends?
I will be going to my shopping center tonight or tomorrow so I will pickup the pieces.
I just reread your comment, I see you understand what happened.
Johnny.
Old Mar 22, 2020 | 03:10 PM
  #33
Veteran: Navy
Ok..got it off Johnny, just trying to see if I can get it flush with that rubber now. I take it the white gear rods holds it in place.
Old Mar 23, 2020 | 07:39 AM
  #34
Administrator
@TeamJones1962 ,
Good morning TJ,
How did you make out, the white gear pieces are actually what adjust the mirror up down, l&r.
I don't want to pull this one apart to figure it out, I don't want to possibly break it.
Johnny
Old Mar 23, 2020 | 12:29 PM
  #35
Veteran: Navy
I got it back on and it moves as it should. I’ll stick the mirror back on and let you know how it holds up.
Old Mar 23, 2020 | 12:35 PM
  #36
Administrator
Great, good to hear !
Old Mar 23, 2020 | 07:04 PM
  #37
Administrator
This piece @TeamJones1962 TJ,
JJJ
Old Apr 12, 2020 | 09:45 PM
  #38
H-M3's Avatar
H-M3 is infamous around these parts
I guess you would need to put LED bulb with resistors preinstalled? What size bulb was it again!
Old Apr 13, 2020 | 04:45 AM
  #39
Veteran: Navy
No resistor. Canbus bulb. I think I ordered the 29mm. Umm have to check in a few.
Edit: 501 led 25mm
C5 led 39mm
Both 5w’s
Old Oct 27, 2021 | 02:00 PM
  #40
Nairb999's Avatar
Nairb999 is infamous around these parts
Led strip in side view mirror
Been following this thread with interest. I have a cracked lens which houses LED strip. How do I remove this unit? Removing the mirror was very straight forward but can’t work out how to remove LED strip unit
mikhail1
Cayenne
May 15, 2025 10:59 AM
ECS Tuning - Porsche
Jan 9, 2015 03:37 PM
sraz786
Sep 13, 2012 10:50 AM
SLP
Cayenne 955/957
Jul 9, 2007 03:04 PM
