How do I clear Fault Roof Code?
Old Dec 14, 2013 | 12:24 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Question How do I clear Fault Roof Code?
I opened my roof while at a stop light while moving slowly (5 MPH) and it threw a Fault Roof Code. Any idea how I clear it? Roof opens and closes fine.
J
Old Dec 14, 2013 | 07:35 PM
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
What exactly is the fault code?
Old Dec 15, 2013 | 09:29 AM
Jeff SD's Avatar
Its says "Fault Roof". I read a post that mentions disconnecting the battery for 5 mins. Supposedly that will clear it.
I'm going to give it a try.
Old Dec 15, 2013 | 10:01 AM
White991TT's Avatar
Im thinking disconnecting battery may trigger other fault codes. You may want to scan the can bus system with a "Vag reader". Will identify the code and related information. I also operate my roof at low speed. Manual says max 25 mph I think. Based on your low speed operation could be coincidental of some other issue.
Old Dec 15, 2013 | 12:31 PM
jmejones's Avatar
jmejones is a jewel in the roughjmejones is a jewel in the roughjmejones is a jewel in the rough
I was told you will have to take it to the dealership. It "should" only happen when you open the roof and you're driving faster then 21 MPH. Salesman told me about it when I purchased.
Old Dec 15, 2013 | 01:43 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
do not disconnect battery to clear it,the only way is with a vas or a vag com. disconnecting battery will set more faults.
Old Dec 15, 2013 | 03:02 PM
Jeff SD's Avatar
Thanks! I'll drop it off at the dealer tomorrow.
Old Dec 16, 2013 | 04:00 PM
Jeff SD's Avatar
Ahhh..The joys of owning a Bentley. The dealer charged me $150 to clear the code..It took the tech 10 mins.
For future reference will this clear the code for me? I'm considering buying one.
VAG305 VAG-COM CAN VW/Audi Car Code Reader : Amazon.com : Automotive VAG305 VAG-COM CAN VW/Audi Car Code Reader : Amazon.com : Automotive
Old Dec 17, 2013 | 03:11 AM
Grwisher's Avatar
Grwisher is a jewel in the roughGrwisher is a jewel in the roughGrwisher is a jewel in the roughGrwisher is a jewel in the rough
I have had this fault code for months and was told that it could be cleared when I had my next service. Did the tech indicate that it was a good thing to have it removed? Or is it just a sign that sometime in the past a roof fault condition occurred and doesn't really indicate any real problems that need to be fixed.
Old Dec 18, 2013 | 09:16 PM
Jeff SD's Avatar
No harm in driving with the fault code. I was just annoyed by it so I had it cleared.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
ModBargains
Oct 13, 2015 03:52 PM
ModBargains
Panamera Vendor Classifieds
Oct 13, 2015 03:51 PM
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
AuZZie
Sep 2, 2015 04:26 PM
