2005 cgt oil change procedure
Old Oct 13, 2014 | 11:25 AM
neishadave's Avatar
neishadave is infamous around these parts
Hello all. It's time for first oil change since ownership, on my 2005 CGT, which I will attempt myself (sigh). Can someone please answer a few questions for me? Is there a jacking point on the front end, where I can place my hydraulic floor jack? Is there any tips or tricks I should know about? I did read that the car should be placed in Jack Mode. Any help on this procedure would be greatly appreciated. Thank you guys.
Old Oct 17, 2014 | 02:27 PM
neishadave's Avatar
This is to help anyone else with safely jacking up their CGT.
I cut 2-6" (2"x6") covered them with a piece of rubber lining (old leaking dock fender, for you boating guys). I put the car at the highest suspension level, then jack mode. Next, lined up the blocks at the jack points listed in the owners manual and carefully used my floor jack. Once at desired height, I put my jack stand as close as possible to jack (on the block of course), then release the jack. NO indentations, NO damages and was able to change the oil easily. DONT FORGET TO PUT THE CAR IN JACK MODE.
Old Oct 17, 2014 | 05:15 PM
djantlive's Avatar
best way to change oil is driving up to a ramp. it is safer and faster.
ramps are $45 btw.
Old Oct 17, 2014 | 05:41 PM
neishadave's Avatar
I thought of doing that, but when I looked up the front axle weight, it was around 3,600lbs. Which ramp can handled that weight?
I looked at race ramps RR-XT and even those are only rated at
3000lbs. Thanks.
Old Oct 21, 2014 | 01:40 AM
djantlive's Avatar
the plastic ramps are rated for 5000 lbs
Old Oct 27, 2014 | 02:16 PM
vanslam's Avatar
vanslam has a spectacular aura aboutvanslam has a spectacular aura aboutvanslam has a spectacular aura about
Hey guys found this oil change and filter service on youtube. Please forgive the dirty car it appears its in China.
Old Oct 27, 2014 | 02:18 PM
vanslam's Avatar
By the way Walmart sells ramps for larger cars and trucks with a 12,000 lb limit for $45.
http://www.walmart.com/ip/RhinoRamps-Black/19526658
Old Oct 28, 2014 | 07:49 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
How to change oil and filter on Bentley Continental - YouTube
Perhaps this should be moved to the DIY thread. By the way, where is the front belly pan in the video? I don't see it being removed and replaced. Also, the tech seems to really crank on that oil filter when re-installing it. He could crush the sealing ring and cause leaks. I also note that he closes the hood by pressing on the center of the cowl. Repeated closing will dent the cowl. You need to press on the outer corners when closing.
Old Oct 28, 2014 | 01:49 PM
vanslam's Avatar
Did you miss the dirt on that engine. LOL. Actually I just did my oil change and its pretty easy. Get the ramps from Walmart aka Wally world, They hold up to 12,000 lbs. Rise the car up on the suspension before you get on the ramp for extra room. Yes i did have to take of a bunch of screws to get the plastic belly cover off. The oil container (filter goes in) is plastic and requires a 36 mm socket/ wrench. The oil bolt is on the drivers side 19 mm. I replaced my bolt. I also got the 3 bolts that hold the belly pain to the front torsion bar. Oh and make sure you have a oil container that can hold 13 quarts, yes I found that at Walmart as well. Once everything is put back on - bolt & oil filter-, then start pouring your oil. I bought (3) 5 gallon jugs of Mobil 1 0W40 at my local, you guessed it Walmart. I also replaced the oil cap's gasket as well. By the way all the other parts cam from a Bentley dealer.
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
