I bought a Neo unit for my 2007 Conti and it works great. You'll have to pull the cd changer to connect it but that wasn't a big deal. http://www.neocaraudio.com/
They don't seem to be offering the same one I bought anymore. While mine has a cable to connect the iPhone I just use the bluetooth to stream music.
Do you control the music on the device or on the factory deck? Reason I ask us that we get tickets for using electronic devices while driving the cops don't care if it's an iPod MP3 player or phone
The CD player seemed to cut out a few times the other day and then it seems ok. I may upgrade to this iPod play system some day especially if the 6 disc player goes out.
I have a flash drive loaded for my Harley CVO Limited with 450+ songs I might rig for that. Without a nice interface for control and song selection that drive is to big to thumb through. The infotainment system on the HD is nearly inadequate for managing such a large flash drive.
I just installed a Neo Mediabridge. Used the Audi one. It is a little difficult programming, but works well after you done. The hardest part was to know insert a screwdriver or something on the side of the cd player to depress the tab (see below) Below are some pics of my installation:
The whole system is operated by using the CD selection buttons (1-6) on the Infotainment system. While using the system you can see which track is playing inside the dash. To change songs you press either the <- or -> selection on steering wheel or infotainment system.
It is important that the first you do after getting the unit is to update the firmware.
The product is the same as for the Audi A8 CDC one (1500 model)
The initial programming is a little hokey, while at first power up the unit was speaking French to me. Then to program it, you have to press CD #1-6 buttons in certain order for it to program Bluetooth or how to play tracks with USB etc.
However, after initial programming, the unit is working great and I have had no issues so far with it. I say it is a lot of value for the money spent.
The installation is simple. The hardest thing was removing the existing CD changer. They will supply you the proper harness to connect into the old CD harness.
