buzzing noise
Old May 25, 2015 | 10:07 PM
bentleydriver05's Avatar
bentleydriver05 is infamous around these parts
buzzing noise
o5 bentley continental makes a buzzing noise every time i press the brakes, what could it be
Old May 26, 2015 | 11:24 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi.
One possibility I can think of is the electric vacuum pump. It is located inside of the front left wheel inner arch, towards the door. If you open the door and try the brakes it should be more apparent. The get noisy with age.
However, if that is the cause and it happens every time you hit the brakes, you might have a leaking vacuum pipe.
Good luck with it.
Les.
Old Apr 19, 2017 | 12:15 PM
jim2331's Avatar
jim2331 is infamous around these parts
...hello driver 05...I am doing research on vacuum pump activating when brakes applied...was yours caused by a vacuum leak...some have that issue without discoverable leak...any information you can provide will be appreciated...JimB
alpha motoring
Oct 2, 2015 12:04 PM
rob4wellness
Oct 2, 2015 07:32 AM
Ronny-
Sep 30, 2015 07:30 PM
