Brake caliper removal
Old Dec 10, 2015 | 01:50 PM
gamocles's Avatar
gamocles is infamous around these parts
Hi all, I have spent several hours researching trying to find how to remove the front calipers from my 07 Bentley GTC, and could use some help. I am replacing the front brakes, and have gotten the hex head bolts off, and it is loose but it isn't coming out. I don't want to force it, in case I'm missing something. None of the diagrams I have seen exactly match my setup. Any suggestions would be greatly appreciated!
ID:	434881   Click image for larger version
Old Dec 10, 2015 | 02:02 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
if you are just changing the pads, have you opened the pistons up slightly, also you need to remove the plate on the front with Bentley written on it. Not sure what you are showing in the second picture, but to remove calliper the steps are ..remove outside plate (bentley written on it, Remove two plastic caps on the inner side so you can access the 7mm hex bolts, loosen those , release the bleed nipple so as you can push back the pistons in the calliper. Then remove calliper from its carrier.
Old Dec 10, 2015 | 03:44 PM
gamocles's Avatar
Awesome, that did the trick! Unfortunately, the Bosch brakes I purchased do not match the brakes on the car. I'm also confused about the pad sensors. They are obviously there and functioning, because my brakes are low and my dash makes sure I know it. However, I don't see how it knows, I don't see any sensor? I also don't see anything about them in the diagram for the assembly. Where are they?
Old Dec 10, 2015 | 09:13 PM
Sensor is on the right hand side from what I remember. Could be the left. But you should see wiring for it
alwaysnboost
Dec 2, 2015 04:17 PM
BOOSTTT
Cayenne
Nov 27, 2015 03:53 PM
no1joey
Nov 22, 2015 03:02 AM
saline
Nov 18, 2015 05:37 PM
supersupercars
Bentley
Nov 17, 2015 03:04 PM
