Tire Pressure Recommendations
Old Mar 26, 2016 | 04:31 PM
cl600bill's Avatar
cl600bill is infamous around these parts
Just ordered a new set of Michelin Pilot Super Sports (275/35/20)for my '06 Continental GT. I saw a number of threads recommending pressures ranging from the door jamb recommendations of 49 in the front to as low as 35. It seems like the higher suggestions are for higher speed driving so I don't think there is a consensus. I am looking for a low noise ride that will not wear out tires. My driving is mostly around town and with highway speeds seldom above 80 mph. I know, you're laughing and thinking "What is this guy doing driving one of our supercars." I suspect there are a lot of opinions on tire pressure and I'd appreciate any thoughts.
Old Mar 26, 2016 | 07:31 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Also use the PSS yet 19" version. I've now settled on 42 front and 36.5 rear with ambient temp being 70f.
Old Apr 12, 2016 | 01:33 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
I've been running 44/40 for years now.
Old Apr 12, 2016 | 04:48 PM
larryr's Avatar
larryr has a spectacular aura aboutlarryr has a spectacular aura about
49/41 lots of weight on the front
Old Apr 13, 2016 | 07:58 AM
My handbook calls for a differential pressure of only 3-5 lbs. I split the difference at 4 pounds and rarely travel over 150 mph.
Old Apr 13, 2016 | 08:38 AM
Have you checked the pressure when hot after a fun Miami drive? Then check the max pressure specs of the tire... just to be safe.
Old Apr 13, 2016 | 11:38 AM
I think he has to much pressure but that is just me. The only reason to run the highest allowable pressures is speed related. If you are not driving over 186 mph there is no reason to accept the harder ride with high pressures. Yes they are front end heavy but a four or five pound difference should be adequate.
Old Jan 21, 2023 | 09:21 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
seriously the preassure to apply is different front and back?
45 psi = 3.1 bar ( i am europe)
3.1 ive never seen at any car - 2.4 - 2.5 bar is stnd
what bentley recommends for europe car versions?
Old Jan 21, 2023 | 09:23 AM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
It should be printed on a sticker on your door jamb.
Old Jan 22, 2023 | 08:01 AM
EJag66's Avatar
5 Year Member
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
On my '14 it is also displayed via the "Car" button on the infotainment system with both actual and recommended pressures. Not sure if that is a change from the Gen 1 to Gen 2.
Old Jan 23, 2023 | 03:53 PM
dangme55's Avatar
dangme55 is infamous around these parts
I am running Pilot Sports at 48/42. Max pressure on the DOT impressions is 50 PSI (Cold) so technically 48 is right at the limit. If you run lower don't forget to set the TPMS to learn the new pressures so you do not get 'Flat' warnings.
I run Nitrogen in all my tires on all my vehicles. So you buy a cylinder and pressure regulator system for about $200. A refill of a 40SCF tank is about $30 and that is a lot of tire fills.
I keep my ride on normal rather than COMFORT and my butt does not complain much - but then again it turned to iron butt after so much motorcycle running. LOL
At any rate watch the tire wear pattern to see if whatever pressure you use has any adverse effects. As I recall over inflated tires wear more in the center, underinflated at the edges and if the 'porridge is 'just right'' the wear will be even (barring any alignment issues.)
Old Jan 23, 2023 | 04:45 PM
BruceR's Avatar
5 Year Member
BTW, when you buy or top up your tires at Costco they use Nitrogen.
Old Jan 24, 2023 | 01:42 AM
sazam's Avatar
i have 20" 275/35/r20 pirelli pzero - preassure should differ per size ?
what is the value add of nitro - never did that before
Old Jan 24, 2023 | 03:03 AM
BruceR's Avatar
5 Year Member
For normal driving (not racing) the benefits are minimal. Nitrogen molecules are bigger than normal air molecules, making it harder for them to leak out. The air we breath is already 78% nitrogen. If you regularly check and maintain your tire pressure there's really not much sense to it. I think that it's mostly a profit maker for those who offer it.
Read this study for more info: https://www.consumerreports.org/tire...s-a6260003694/
Old Jan 24, 2023 | 08:58 AM
dangme55's Avatar
All correct and here is another link on the pro's/ con's.
https://cars.usnews.com/cars-trucks/...rogen-in-tires
I have used it in all my Corvettes, etc. the main advantage is that commercial tanks are 'dry' gas. Most folks do not have dryer/water traps on their compressors.
IMO for the Bentley the constancy of pressure is a factor. Since the recommended pressures are so close to the max cold inflation that might help.
Again as @BruceR says a lot of this is esoteric 'how many angels can dance .......' talk
I have never paid for N2 as it is a big profit center at a tire shop. I keep my tank and hi/lo setup which is long paid for.
vintageracer65
Bentley
Mar 23, 2018 07:29 AM
markj
Dec 13, 2015 08:46 PM
hella-buggin
Dec 28, 2009 04:50 AM
Noffy
Nov 20, 2009 05:03 PM
seattle_sun
Sep 18, 2007 12:39 PM
