Bentley Tech removing my Engine
Old Aug 4, 2016 | 02:56 AM
BentleyF's Avatar
BentleyF is infamous around these parts
This shows Jason giannetti pulling my engine...
he did this with no one helping him. amazing
Old Aug 4, 2016 | 03:04 AM
BentleyF's Avatar
Old Aug 4, 2016 | 05:06 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
i wonder why the engine need to remove?
for doing the vaccum line or any other fault come with it also
please give more detail
Old Aug 4, 2016 | 12:56 PM
BentleyF's Avatar
why? engine was removed
I had the engine and transmission replaced, my suspension calibrated new built vac lines made of steel tubing.( so the leak will never happen again) I had tie rods installed, new BMC air filters installed, he gave me rotors that were better than mine, also installed another vac pump as mine had bit the dust. he also replaced the radiator that I supplied as mines had a small leak.
new hoses, two new tires and he mounted and aligned car also corrected my ride height ride height. my old trans bit the dust after 180,000 miles the thermostat and alternator went bad as well so I decided I wanted to keep the car I then searched for a engine and trans from a wrecked car. my car I swear is like brand new now thanks to
Jason Giannetti of Giannetti performance 516 398-2016.
so far as engine out I wanted it done the correct way,he is bentley trained and lamborghini trained. I hope this helps someone who is tired of being taken...
Old Aug 4, 2016 | 07:34 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
HI BentleyF,
I also just got my vacuum line repaired but used the OEM line (plastic) rather than custom metal line. Did your mechanic say anything about the newer OEM vacuum line ?
I wonder if Bentley fixed the issue because I don't want my engine out again.
Old Aug 4, 2016 | 09:00 PM
BentleyF's Avatar
He told me he just serviced a 2014 gtc and it still has the same line.
Old Aug 4, 2016 | 09:02 PM
lilo1980's Avatar
Ok thanks. Knock on the woods hope I won't have the same problem for another 60k or 10 year s
Old Aug 4, 2016 | 09:08 PM
BentleyF's Avatar
Was your work done at dealership? IF so how much did it set you back?
Old Aug 4, 2016 | 09:20 PM
lilo1980's Avatar
My job was done at my local Indy. I needed bunch of stuffs like turbo solenoids, exhaust temp sensors, new drive belt, tensioners, bunch of hoses, anti-rollbar drop links, relay roller.
My bought all the parts myself except the vacuum hose.
I haven't got my total bill yet but the labour will probably be around 50+ hours. I forgot the exact labour rate but it is somewhere in the ballpark of $100-$120/hr.
One thing I forgot to do is to replace the starter motor. It is a good idea to replace it while the engine it out. I only found out once the engine was back in.
My brakes, suspension, and engine are now all refurbished. Knock on the woods and hope there is no major repair soon.
Old Aug 4, 2016 | 09:49 PM
BentleyF's Avatar
I put 180,000 miles on my starter and my car was daily driven and my starter was still fine. the alternator did go out though. I think you will be fine...
Old Aug 6, 2016 | 12:26 AM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
Wow 180k miles that good to hear! I got 70k miles on my removed the engine myself heres a timelapse video i did. Took me 10 hours to take it out.
Old Aug 6, 2016 | 02:19 AM
BentleyF's Avatar
all I can say is wow! Nice Car.
Old Aug 6, 2016 | 10:14 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
180,000 miles is most impressive!
Old Aug 6, 2016 | 10:35 AM
@ bentley F
thank you so much for the reply
so u replace the air suspension line by a steel tubing line? where did u bought that line? would u please take a pic of it
and i have one more question?
why u need to replace your engine and your trans? does the engine burning oil or anything else? would u please detail about it
Old Aug 6, 2016 | 10:59 AM
Johnny Hotspur GT's Avatar
Administrator
Originally Posted by nguyennhatquang
@ bentley F
Please read post # 4 again,
His transmission went bad along with some other things, so he purchased a complete used package {ENGINE & TRANS} and had it installed.
As far as the line replacement, it is NOT for the suspension, it IS for the vacuum circuit, just watch the videos he posted of Jason performing the smoke test, ALSO Jason hand bent the vacuum lines for the install.
