Light bulb warning light suggestions
Old Aug 9, 2016 | 07:34 AM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
Hi,
I have a warning light on my cluster letting me know there is a bulb problem on my 05 CGT. I scanned the car with VCDS and the attached photo shows the result. I cleared the code and the light goes off. As soon as I touch the brake pedal it pops back on. I have disconnected and reconnected anything I could on the lights, still get the same warning light. Both rear lights are working as they should.
Anyone have any suggestions on what I should look at or try next to keep the warning light from coming on?
Thanks.
Paul
Old Aug 9, 2016 | 08:05 AM
Johnny Hotspur GT's Avatar
Administrator
Hello Paul,
For each taillight there is a ground wire and stud on the body right below the taillights, brown wire, remove and clean them, make sure they are snug, also check the pins and plugs for corrosion, clean them with some electrical cleaner, is your 3rd brake light working ?
Old Aug 9, 2016 | 08:12 AM
pwc6t3's Avatar
Hello Paul,
Thanks Johnny I will give that a try. Yes the third brake light works fine.
Paul
Old Jan 22, 2017 | 11:03 AM
jim2331's Avatar
jim2331 is infamous around these parts
....Johnny knows these cars inside and out...did that cure the problemm...JimB
Old Jan 22, 2017 | 11:07 AM
pwc6t3's Avatar
Hi Jim,
I cleaned the connections and made sure everything was tight. I have not yet removed the grounds and given them a good cleaning. So far the issue isn't resolved.
Paul
Old Jan 22, 2017 | 12:24 PM
jim2331's Avatar
....you know much more about electronics than I do, but I know there are people on this site who can help you...have you ever done r/r on the main battery...I am involved now first time with excellent help from Johnny...mine is 2010 Speed
REDNOSEGT
Bentley
25
Feb 12, 2024 06:39 AM
tommyboy214
Apr 4, 2016 07:31 PM
Polar993
Mar 24, 2016 01:04 PM
luting_chen
Aug 25, 2003 07:43 PM
kparis
Jul 19, 2003 10:21 PM
