GROM Audio VAGTU3 Bluetooth
Old May 22, 2020 | 06:37 PM
TungNguyen's Avatar
TungNguyen is infamous around these parts
Originally Posted by cerex
2007 Bentley Continental GT
Just installed the GROM system as described by Rottboy above.
I am using the OEM bluetooth for calls and GROM to stream my music. Running off an iPhone 11 Pro
no issues sound quality is great, steering wheel mounted controls all work took me under 10 minutes
Very straight forward plug and play install.
used a heavy duty Velcro to creat a mount for the GROM system to stay in place.
happy driving
Hi, can you share the OEM bluetooth you are using for phone? When you have a call, is the music paused or silenced? Many thanks!
Old May 22, 2020 | 07:23 PM
cerex's Avatar
cerex is infamous around these parts
When I get a call the music pauses and restarts after I hang up. Like I said it is through the OEM Bentley upgraded system, with functional Dash and Steering Wheel controls. It does not however display the song titles just the track. I did get the usb connection as well but have not installed that yet.
https://www.6speedonline.com/forums/...ley-phone.html
Take a look at the thread above, posts #70 - #79 will tell you all about how I got bluetooth to work with IPhone X and iPhone 11 Pro.
You will see my details on what I did in the trunk ceiling to upgrade the original Bluetooth phone module in my 07 Bentley GT to a later year flying spur model that was a compatible unit with a software upgrade. Will require taking a few things apart in the swap.
There are a few clarifications but the first few posts will tell you what worked and Through the post on what didn’t work, there were several attempts and failures before it all worked out.
karlfranz
Jun 8, 2023 07:09 AM
Perkunas
Bentley
Aug 27, 2018 02:02 PM
914rrr
Oct 9, 2015 01:47 PM
fairbird
10
Oct 11, 2013 11:01 AM
terry007
Tech / How To
Jul 31, 2008 08:35 PM
