Front right wheel noise
Old May 31, 2017 | 05:45 PM
SnoJade Jan's Avatar
SnoJade Jan is infamous around these parts
Unhappy Front right wheel noise
I have a 2011 Bentley continental flying spur. I have noticed a ticking sound from the front right wheel ONLY when turning left. I went to a luxury car dealer and they said it is a common problem. I am so embarrassed to drive the car when it makes this noise. Anybody have/had the same issue and what was the solution. Thank you
Old Jun 1, 2017 | 01:25 AM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
I know how you feel. I had the clicking noise in two separate occasion and were caused by two different faults:
1. If you have two-piece wheel, there might be something broken in the wheel to cause the clicking. Try to swap the wheel to another side and see if it shows up on the other side
2. Your control arm might be bad
Do #1 first. If it still persists, then it is something related to your suspension. It won't be an expensive fix. Probably ~$1k parts + labours.
Old Jun 1, 2017 | 10:57 AM
Daddy C.'s Avatar
Daddy C. is a jewel in the roughDaddy C. is a jewel in the roughDaddy C. is a jewel in the rough
if it's a clicking sound rather than a clonking one, it might be the brakepad(s) you here with the pistons 'retracted'. Rather common problem, GTR's have suffered same issue.
Do you hear the noise when you turn and brake at the same time?
Old Jun 1, 2017 | 08:44 PM
Thanks. I'll give that a try.
Old Jun 1, 2017 | 08:48 PM
I only here it when I turn the wheel to the left , I don't brake . I just had my brakepads changed.
Old Jun 4, 2017 | 11:53 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
I am assuming you have checked the right front wheel bearing?
Old Oct 10, 2020 | 04:40 AM
unigenitus's Avatar
5 Year Member
unigenitus is infamous around these parts
Resurrecting this thread.
I have a 2007 GTC and with the roof down I have noticed a crackling sound coming from somewhere on the front left side of the car, it "feels" like from the outside. At first it sounded like a piece of paper or material flapping around in the wind, but on closer listening it seems like it must be something else and I fear possibly serious unless stopped. Has anyone had such a problem? It becomes quite intense after driving a while.
Old Oct 11, 2020 | 11:37 AM
MulsanneTurbo's Avatar
MulsanneTurbo is infamous around these parts
Hi. I had a very similar issue - a cracking sound, almost like an electrical sound from my front right wheel.
My Indy eventually traced the cause to a broken tyre pressure sensor, a part of which was rattling around inside the wheel. They removed it at minimal cost and all well.
Old Oct 11, 2020 | 06:33 PM
unigenitus's Avatar
5 Year Member
Thanks, I believe I may have read your reply elsewhere and intend to lead with this idea at the mechanic this week!
