2007 Bentley Continental GT Air Suspension Failure
Old Aug 28, 2022 | 02:54 PM
  #61
EJag66's Avatar
5 Year Member
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
Yep, sounds pretty sketchy. If it is advertised as "re-manufactured" it must be in "as new" condition and meet all the same inspection requirements of a new unit, otherwise it is simply "re-built" or "repaired" and you get what you get.
Old Mar 13, 2023 | 06:07 PM
  #62
Shaqovic's Avatar
5 Year Member
Shaqovic is infamous around these parts
Originally Posted by Randy V
Hey guys - are the Arnott struts recommended here? I recall Johnny HS indicated an issue with a vendor that was claiming to 'rebuild' struts but was actually only painting them. Maybe not Arnott.
Also, are Arnott available in USA? I'll be needing to replace my struts soon and would like to know a source for an Audi or VW part at the lower cost.
Appreciate any leads!
same here looking at VW 4E0616040 if it fits Bentley GT 2005
have you found the answer ?
Old Mar 13, 2023 | 09:35 PM
  #63
belton's Avatar
belton is infamous around these parts
Arnott struts
Some years back I replaced the front struts with RMT units. They were cheaper, but what a mistake. The shock absorbers were essentially inoperable, and made terrible noises.
Others have written about Arnott struts with "rebuilt" dampers. I chose to replace the RMT struts with Arnott struts with new dampers, shock absorbers. They have worked well for the last 4 years. Arnott now offers struts with Bilstein(?) shocks. If I have to do this again, I might try them.
The job of changing the struts is not that bad. It helps to have a lift, but it is not necessary. Arnott has very good directions on their website.
Hope this helps.
microboby
Bentley
20
Mar 24, 2023 08:04 AM
belton
Bentley
22
Oct 6, 2020 10:11 AM
philberticus
Bentley
May 11, 2018 08:13 PM
Lars_Tempest
Bentley
18
Apr 21, 2017 09:17 AM
rdsrllc
Bentley
19
Jul 1, 2015 10:35 AM
