Bentley GTC airbag failure warning light
Old Nov 5, 2017 | 10:49 AM
rangrov's Avatar
rangrov is infamous around these parts
Hi guys out in my 2007 GTC today. The airbag waning light came on. It just leaves a yellow symbol in the rev counter, no other symptoms car runs fine. Has anyone any ideas or had this problem before. Thanks.
Old Nov 6, 2017 | 10:26 AM
rangrov's Avatar
Any ideas guys.
Old Nov 6, 2017 | 11:07 AM
Johnny Hotspur GT's Avatar
Administrator
Originally Posted by rangrov
Any ideas guys.
Sorry, there is no quick easy answer, you will need a scan, do you have a Ross-Tech setup, or VAS ?
Old Nov 6, 2017 | 01:08 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Scan, maybe just needs to be cleared.
Old Nov 6, 2017 | 01:27 PM
rangrov's Avatar
Hi guys sorry I have no equipment. I've tried switching the ignition on and off every 5 seconds. I've checked under the seat but can not see any lose connections also moved the seat around and lubriated the seat belt inserts. All to no avail.
Old Nov 6, 2017 | 02:29 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
you can clear the codes by disconnecting and reconnecting the batteries. Using the search function on this forum, you will find many instructions on the proper procedure. Make sure you read these before attempting.
Old Nov 8, 2017 | 12:37 AM
rangrov's Avatar
Hi I don't fancy disconnecting the battery in case I raise other problems. Plus I suppose I can live with the light on the dash as long as it's not doing any damage. Advice needed. Thanks.
Old Nov 11, 2017 | 02:50 PM
WelshBentleyBoy's Avatar
WelshBentleyBoy is infamous around these parts
This is a problem easily sorted by a dealer with the proper equipment in about ten minutes. The possibility however is that there may be a problem with the system that would prevent it carrying its intended function in an emergency.
This cannot be worth taking a chance on. Go and get it checked out !!
Paul
Old Nov 12, 2017 | 10:16 AM
quarryman's Avatar
5 Year Member
quarryman is infamous around these parts
Hi, did you move either seat forward or backwards prior to the light coming on ?
Old Nov 15, 2017 | 02:41 AM
rangrov's Avatar
Hi no the car was being manoeuvred slowly and the light just came on. I had not moved the seat in any way, also I have noticed the seat belt warning light if it has one does not come on or flash if you drive without the seat belt being fastened. I don't know if this is related. Thanks for your time guys.
Old Nov 15, 2017 | 02:08 PM
Come on!!!
Get it plugged into a scanner and all will be revealed!
This is not rocket science
Paul
Old Nov 16, 2017 | 05:24 PM
What he said.
