Overhead lights and clock fuse
Old Nov 21, 2017 | 02:55 PM
dkfandi's Avatar
dkfandi is infamous around these parts
I have a 2013 Bentley GT V8. The overhead lights and the dashboard clock went out so i took to the dealer. They charged me $195 for fuse repair lmao and the clock and lights worked again. 2 days later fuse went out again. I replace it 3 times and the fuse blows within 3 days. Any ideas on what could be causing that fuse to trip? Thank you
Old Nov 10, 2019 | 04:19 PM
espitzer1's Avatar
espitzer1 is infamous around these parts
Bentley 2013 Clock Fuse
Where is the fuse for a 2013 Bentley Flying Spur located and which fuse is it???
Old Nov 11, 2019 | 06:31 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
It’s a short somewhere. If your comfortable with taking the dash apart, start by disconnecting the clock for a few days to see if it blows again. My gut tells me it would be the overhead lights before the clock tho. I don’t have my car at the moment to check, but see if the lights under the bottom of the doors work also. See if they go out when the fuse blows too. I would guess it may be a short in one of them. Maybe water egress.
Did this just start out of the blue?
MYC2SPC
Jul 22, 2015 06:05 PM
doramon1313
Aug 11, 2014 08:37 AM
Domer911
Feb 17, 2013 08:19 PM
DNugget991GT3
Oct 11, 2011 01:10 AM
Powell
Jun 27, 2010 05:44 AM
