2004 Bentley boot leaking
Old Mar 29, 2018 | 03:22 AM
Ellie's Avatar
Ellie is infamous around these parts
we have recently got a 2004 Bentley gt continental and when it rains and you open the boot the inside of the boot floods with rain water, does anyone else have this problem or knows a way to fix it?
Old Mar 29, 2018 | 06:04 AM
MikeH's Avatar
MikeH is infamous around these parts
This is usually blocked aerofoil drains which run from underneath your rear spoiler to the boot lip
More info here: https://www.6speedonline.com/forums/...unt-water.html
Old Mar 30, 2018 | 09:06 AM
sam08861's Avatar
5 Year Member
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Also check the drain next to the gas filler under the cover. Theres a small hole there. I reamed mine with the plastic filament used for weedwhackers and it did the trick.
I'd suggest removing the spare to really dry things out with a towel and check the ports where the wire looms go through there for any water in the rubber grommets.
Bozz30
Bentley
Apr 21, 2016 11:05 PM
alevine
May 21, 2005 11:53 AM
JK996TT
Jun 28, 2004 07:55 AM
