Vag Com question
Old Jun 12, 2018 | 12:19 PM
gtjay's Avatar
gtjay is infamous around these parts
Vag Com question
Hey guys still a little new here to the forum. I wanted to know is there a specific VAG COM needed to work on a Bentley? Because most the ones I see say only VW and Audi Skoodi etc. But I know bentley is VW to the T. Thanks for any suggestions and if anyone can recommend a good cheap one
Old Jun 12, 2018 | 12:48 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
VAS5054A gives you everything you need. Not cheap and not easy to understand as it is for Bentley trained techs.
Old Jun 12, 2018 | 04:22 PM
Daniel Clohessy's Avatar
Daniel Clohessy is infamous around these parts
Legitimate Ross-Tech VAG-COM will function for everything you need to do. I use it currently, and have not had an issue yet.
Old Jun 12, 2018 | 07:00 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
I use Ross-Tech VCDS.
Old Jun 13, 2018 | 10:41 AM
steve.2.lowe's Avatar
steve.2.lowe is infamous around these parts
VAG-COM is now called VCDS.
Old Jun 13, 2018 | 03:35 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Experimenting, I bought a xtool vag401 Chinese knock-off scanner. I cannot endorse this for other users because sometimes they work great sometimes they work okay and sometimes they just don't work. As for in the glove box convenience costing only $50 I like it. On a side note on earlier Bentleys it can retrieve the pin number, the four-digit secret key code.
That said it is not an absolute replacement for a Ross Tech vcds. With the Ross Tech you get a lot of support and a fantastic interphase.
jnbr19867
Audi
Jan 13, 2008 01:22 PM
pbfoot
Audi
25
Jan 9, 2008 11:33 PM
villains_turbo
Apr 4, 2007 08:28 PM
02barebones996
Audi
Jul 14, 2006 01:55 AM
RWDRIFTC2
Aug 20, 2004 10:33 PM
