Overheating and no heat, Bentley Flying Spur
Old Dec 8, 2018 | 02:11 PM
ssonss1's Avatar
ssonss1 has a spectacular aura aboutssonss1 has a spectacular aura aboutssonss1 has a spectacular aura about
Hi everyone, the car is a 2006 Bentley Flying Spur with 90k miles. Here is a quick rundown of events leading up to this: In August the water pump was sweating coolant, indy decided to change the pump and gasket before it got worse. Fast forward to November, the car started to creep above the 200*F, as expected the fans would kick in and move the gauge back to 200. At idle the fans would go pretty loud but as I drove it would be fine.
Now here is the current issue, 2 days ago the car randomly stopped blowing heat, AC works fine just no heat. The indy bled the coolant thinking maybe there was air in the system, but still nothing. On the drive home the car went well past 200*F and I turned the car off to cool down then got it home once it went back to operating temperature. Also I noticed if I turn the fans off on the heater and wait 2-3 minutes, once I turn it back on it will blow heat for about 5-10 seconds then become cold again.
The indy is suspecting a bad thermostat. Any ideas before I send her to the dealer? Thanks
Old Dec 8, 2018 | 05:30 PM
Johnny Hotspur GT's Avatar
Administrator
Hello Ssonss,
I am going to go with it is the thermostat also, you most likely have one that is stuck partially open, meaning more closed then open, causing the higher then normal temps at the block and the fans to go full blast cooling the what most likely is not up to normal operating temp coolant in the radiator to flow to the heater cores (there are 2), it is a screwy system as in why the fans run full blast, it is just a safety measure, my 05 W12 A8L had a bad coolant temp sensor back about seven years ago, it would give the big red temp sign in the DIS, and the temp gauge would be on it's way up to normal 12 o'clock positions, then fall to C, the fans would go jet speed, so I changed that sensor and all was fine for a while, then at the end of last winter it started again, I was about to do the sensor again but I instead cleared the code and all was fine, and I put the Torque OBD app on my phone for easy clearing of the code if it popped up again, yes I was putting it off as it was fine this past spring, summer, and fall, now fast forward to right right now I come to realize (what I had already known and put off) that I have a fully stuck open thermostat which for the summer months was fine, never got hot, and no warnings, but now have the big red temp warning from time to time, BUT of most importance is the engine temp will not get up to the proper operating temp, and even though it is below op temp the fans will come on making it even colder, therefore no heat, or very little when stopped and idling, forget about driving at highway speeds, I did find that if I drive in 3rd or 4th gear instead of 5th and 6th I get heat, hence it points to a wide open thermostat for me.
See link, also the thermo is not available separately, you most buy the whole housing with the heater element and thermo as one, even though the thermostat is removable from the housing as I showed in the link... the 04's to sometime in 07 have the heater element, the later 07 block I tore down did not have the heater, I have a few very low mileage 05-06 used pieces if interested.
Johnny aka Giovanni.
https://www.audiworld.com/forums/a8-...ature-2928224/
Last edited by Johnny Hotspur GT; Feb 20, 2020 at 06:29 PM. Reason: Fall to C, not full to C
Old Dec 9, 2018 | 05:38 PM
sspeeder's Avatar
sspeeder is infamous around these parts
I wouldn't discard the possible failure of the auxiliary cooling pump. This pump is electrical and is located in front of the front left wheel. If you take out the inner fender wheel arch liner panel you will be able to access the pump.
Switch on the ignition and grab the pump with one hand. If it is working you will be able to feel it.
Poor heater efficiency when the car is idling or moving slow in traffic is often due to this pump not running as it should. I wouldn't go into the thermostat possibility before I was able to rule out this pump.
After all it is indeed an easy check that will take you less than half hour.
Old Dec 10, 2018 | 12:48 AM
ssonss1's Avatar
Hello Ssonss,
I am going to go with it is the thermostat also, you most likely have one that is stuck partially open, meaning more closed then open, causing the higher then normal temps at the block and the fans to go full blast cooling the what most likely is not up to normal operating temp coolant in the radiator to flow to the heater cores (there are 2), it is a screwy system as in why the fans run full blast, it is just a safety measure, my 05 W12 A8L had a bad coolant temp sensor back about seven years ago, it would give the big red temp sign in the DIS, and the temp gauge would be on it's way up to normal 12 o'clock positions, then full to C, the fans would go jet speed, so I changed that sensor and all was fine for a while, then at the end of last winter it started again, I was about to do the sensor again but I instead cleared the code and all was fine, and I put the Torque OBD app on my phone for easy clearing of the code if it popped up again, yes I was putting it off as it was fine this past spring, summer, and fall, now fast forward to right right now I come to realize (what I had already known and put off) that I have a fully stuck open thermostat which for the summer months was fine, never got hot, and no warnings, but now have the big red temp warning from time to time, BUT of most importance is the engine temp will not get up to the proper operating temp, and even though it is below op temp the fans will come on making it even colder, therefore no heat, or very little when stopped and idling, forget about driving at highway speeds, I did find that if I drive in 3rd or 4th gear instead of 5th and 6th I get heat, hence it points to a wide open thermostat for me.
Thank you for the reply, I will shoot you a dm
Thank you, will definitely have this checked out.
Old Dec 10, 2018 | 01:43 PM
Administrator
Hello sspedder,
Unless I am missing something, and I may be, (I will look tonight) there is no auxiliary water pump in the left hand wheel house under the liner, the pump located there is the vacuum pump for the vacuum circuit when on boost, the auxiliary pump that you may be thinking of is located as pictured over the transmission in two different locations for the Spur VS. GT, with the GT being at the far end of the trans, while the Spur has it located mid-way of trans, also, this auxiliary pump is for the cooling of the turbo chargers, and to date I have not heard of one failing, at least not on here.
Johnny
Old Dec 10, 2018 | 03:26 PM
sspeeder's Avatar
Hello Johnny
Efectively these vehicles do have a turbo cooling pump (after run) that is very similar to the auxiliary cooling pump I am talking about.
n fact it is they even have both the same part number, The auxiliary cooling pump I am talking about is 3W0965561 and the after run pump you mentioned is part number 3W0965561C
I attach pictures of them both.
Last edited by sspeeder; Dec 10, 2018 at 03:31 PM. Reason: don't see my attachments
Old Dec 10, 2018 | 03:29 PM
Administrator
I stand corrected, I think...
This does appear to be as sspeeder stated, so that makes two electric coolant pumps so far.
Blue GT pic is of when Zaos did his engine pull.
Johnny
Old Dec 10, 2018 | 03:34 PM
Administrator
Hello Johnny
Thank you sspeeder, I will definitely verify the operation of both before I complete my rebuild.
Johnny
Old Dec 10, 2018 | 03:46 PM
sspeeder's Avatar
By the way Johnny, I do agree with you when you say that you don't know of any failing. In fact they are very reliable considering that these electric pumps operate all the time from the moment you switch on your ignition. However there is history of cases of failure with similar results to what ssonss1 described above. And if this pump has failed, in his case is a lot simpler and less expensive repair
Old Feb 20, 2020 | 10:24 AM
Ivo Pjencak's Avatar
Ivo Pjencak is infamous around these parts
Coolant pump 2 / thermostat
Hi guys,
can someone help me please? My VCDS reports error 005644 coolant pump 2. I don't know anymore. The pump turns on, but after a while (10sec) it turns off and the error code starts up. Cables are in order,
I checked the fuses and relays. Is it normal for the Group 139 thermostat to show -48 ° C? I'm looking for some connection.
I am sorry for my english
Thermostat
Coolant pump
Old Apr 11, 2022 | 08:04 AM
Kent K's Avatar
Kent K is infamous around these parts
Coolant Pump 2, Error code 00564
A greeting from TAIWAN. I got a 06 Continental GT, and it runs okay~
Recently, the Engine light on and I have my car scanned by VCD and other scanner systems
All signs indicate that the "Coolant Pump 2" is broken.
Two issues experienced:
1. The car has had no heater at all for almost one year, no matter what temp I turn on, it only offers very cold air.
I thought it was fine because the weather in Taiwan is always very hot, thus, no heater doesn't bother me.
2. The Engine light is on, the VCD indicates that the Coolant Pump 2 failed, with error code 005644
Very similar to Ivo Pjencak's picture, but I only got 005644 error code.
Four questions here
1. Is that a fault caused by the Coolant Pump 2? or, is that something wrong with the Thermostat?
I have had no heater for almost one year, but the engine light just shows recently.
2. How to Identify whether I got a broken Coolant Pump 2 or the Thermostat?
3. If I have to replace the Coolant pump 2, is it located in front of the front left wheel, just as what was quoted?
4. The
Coolant pump 2 is only used in Bentley, or, is it also used by other VW/Audi cars?
By the way, the temp of the car is always just below 200 ℉, never over 200 ℉
Many thanks, my good friends.
Hope the issues can be solved in a near foreseeable future.
Johnny
Old Apr 11, 2022 | 03:16 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Hello Kent K,
To test the coolant pump, remove the left front inner wheel liner. Start the vehicle or possibly put the key in position 2. Should be able to feel the water cooling pump motor running, as stated earlier in this thread.
cluk
Bentley
Dec 4, 2018 04:56 AM
hammond
Bentley
Jul 18, 2018 12:43 AM
spencerusa
Mar 27, 2016 07:31 AM
SILVERFOX
Oct 10, 2014 01:35 PM
M3CAB
Mar 10, 2012 03:55 PM
