Thank you for the explanation, do find it crazy that the factory would set it 100 miles an hour when the legal speed limit is set at 70 but the law lets us get away with 80 ...
Do you have a link Rico I'm not familiar with Ross tech
Ross tech "wiki": Research Ross Tech vcds online. This is the best way to scan the ecu's in a Bentley. Without this tool while working extensively on the car especially disconnecting batteries total clearing of ECU stored trouble codes is important. This is a windows-based program that works with Ross Tech's data cable to the OBD port under the dash. This works beyond standard generic trouble codes.
Ross tech "wiki": Research Ross Tech vcds online. This is the best way to scan the ecu's in a Bentley. Without this tool while working extensively on the car especially disconnecting batteries total clearing of ECU stored trouble codes is important. This is a windows-based program that works with Ross Tech's data cable to the OBD port under the dash. this works beyond standard generic trouble codes.
Would you know where I can purchase one I've got a cheap diag but I need the vcds one really I was just unsure what one to get.
Sadly I do not have a manual also I'm not sure but I think my spoiler only goes to three positions I'll check again .shame we can't post videos here as I could show you
Simply log on to Ross Tech vcds. The best option is the enthusiast version. You will receive a cable from them. This version will allow licensing of three vehicles to the program. A computer running Windows 7 or newer is required. An Apple computer will not be compatible even with a virtual windows program.
Once you have the cable the program is downloaded off the Ross Tech website. They do not send a program just the cable. Therefore internet conductivity is necessary
There's a learning curve using the above tool. However this will greatly improve your navigation through Bentley
I've not got that cover but I don't think it's operational it just keeps the dirt off doesn't it
I'm sure you can understand i don't want to pull mine of just in case, but i think if you have a part missing then this is why its not working right ???
