Bgtc rear spoiler
Old Jul 28, 2019 | 10:40 PM
  #46
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
Originally Posted by Yoghurtshotgun
Ok on inspection the motor is exactly the same as one used for the Bentley Samer serial etc do that our if the question I'll go through what it does .if I sit in car ignition on no start,I press up and is raises in three stages then returns to rest closed and illuminates dash light.if I start car and drive it pops up one stage then returns to rest and illuminates light and won't work with buttons .
I will check wiring tomorrow I'm determined to sort this
With the car stationery & with the ignition on when you press the button to raise the spoiler it should go up in one sweep and when pressed to retract (close) it should go down in 3 stages ... You are saying when you press the button to raise the spoiler it goes up in 3 stages, so when you press the button to retract it does it close in one sweep or 3 stages ...
Old Aug 13, 2019 | 03:36 PM
  #47
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Originally Posted by 1eapplebaum
Read through this attachd old post there's information on the airfoil.Bentley Continental GT/GTC/Flying Spur DIY Thread - Page 4 - 6SpeedOnline - Porsche Forum and Luxury Car Resource https://www.6speedonline.com/forums/...-thread-4.html
Yoghurtshotgun
Bentley
Jun 26, 2019 05:48 AM
fmanley2
Feb 17, 2014 05:31 AM
Terminator
Jan 31, 2014 10:04 AM
Sotally Tober
Jan 14, 2004 12:05 AM
